lol well said. well said.benemorius wrote:When the a$$ at autozone tries to sell you GL5 because it meets GL4 standards, TURN AND RUN.
What are syncros?? can anybody help me out?sds14240sx wrote:the problem is your syncros ther are messed up the nissand trannys and gearboxes suck. i had the same problem. get a new transmission or rebuild your transmission. also if you are speed shifting your shift forks could be f****D up too. changing the fluid will not do anything. but if you want to try it, pour some friction modifier in first through the shifter.
So basically my transmission's f*cked then right? (if it is my syncros) Is there any way i can fix it other than get a new transmission? And is it just mine or do all KA's have sucky *** gearboxes?sds14240sx wrote:SYNCROS LINE UP THE GEARS WHEN YOU SHIFT. WHEN THEY ARE WORN YOU GEARS WONT LINE UP PROPERLY AND YOU GEARS WILL GRIND. YOUR SHIFTER CAN ALSO POP OUT OF GEAR, AND YOUR GEARS WILL LOCK OUT.
Ay Caramba!This happened to my transmission....It was stuck in gear, and the shifter was locked out of the other gears... (5th gear and reverse will not engage at all) I took off the shifter plate and looked in, to me it looked bone dry...and we just put in 2qts when we changed the clutch.sds14240sx wrote:SYNCROS LINE UP THE GEARS WHEN YOU SHIFT. WHEN THEY ARE WORN YOU GEARS WONT LINE UP PROPERLY AND YOU GEARS WILL GRIND. YOUR SHIFTER CAN ALSO POP OUT OF GEAR, AND YOUR GEARS WILL LOCK OUT.
No your not ****ed. Driving with synchros can be done, it just requires adjusting your driving style.WI_S14_Goldie wrote: So basically my transmission's f*cked then right? (if it is my syncros) Is there any way i can fix it other than get a new transmission? And is it just mine or do all KA's have sucky *** gearboxes?
