Is 20x10.5 too wide for the front?
twostep361
Car: qx80
is 20x10.5 to wide for the front,well i know it is. but will it work? LOL
I found some wheels cheap 20x10.5
will a 36 offset work ? tires was thinking 255/40/20 will a little stretch tire height is 28 with the stretch it should be a tad shorter. or a 275 35 20
was leaning towards the 255 because its not as wide,hoping it helps with the tracking.
or could i use my stock 245 40 20 or will it to stretched?
Debonair
Car: 2011 Infiniti M56
This may help or may not. I don't think it was a tire issue but I'm not sure.
Altered wrote:Just in case anyone is interested in knowing, a 20X10.5 +45 will not fit the front, tried it on my car.
Found in this thread: Rim option
Altered
Car: 2013 Infiniti M37x
I can't say for sure if 20x10.5 +36 will fit but it MAY. I had 20x10 +35 and it was close, maybe a centimeter between the rim and the suspension. 255/40 20 will definitely fit that size wheel, but if the car is AWD you want to make sure the rear is either the same size or a 285/35 or 295/35, they are the ideal stagger sizes for that 255/40.
If that's the only issue I'd say buy them, if a spacer is needed it will be very small but the 10.5 will fill the wheel well very nicely.
twostep361
Car: qx80
well they said they didn't know and didn't recommend to buy it,so they offered me some cv1 vossens for 800shipped
two things i didn't like 20x9 squared,and the there 5x112 there gonna redrill them.
i wanted 10.5 for the rear least!
Altered
Just get the +36 10.5s, it won't be that bad. Plus for the price you can't go wrong. There's only one way to find out if they fit...
twostep361
Car: qx80
would anyone you run a bronze wheel on a moonlight white? or to tuner style?
on there webpage they have a m56 20x10 with 40 offset.
http://www.nicheroadwheels.com/form-m158-w-20332.htm
Debonair
twostep361 wrote:would anyone you run a bronze wheel on a moonlight white? or to tuner style?
Bronze on white looks awesome. "Too tuner" would really depend on the wheel style more then the color in this case IMO. That wheel you picked looks great..
I would be happy to photoshop them onto a white M if you want. The Q50 they have on that site is pretty close too.
twostep361
Car: qx80
Yea could you photo shop but with rear wheels all the way around ?
I want the concave of the 10.5
I've seen some q50's with 10.5 all the way around on youtube,if they can do it,i don't see why not on a M.
gonna make some call tomorrow to niche and see what they recommend
Debonair
Here you go. Not perfect but they will help you visualize it. :dblthumb:
Stock:
Dropped:
twostep361
Car: qx80
thanks
i just called up concept one wheels and they said a 10.5 will fit all the way around with a 15-25 offset.
i was looking on myg37.com and there dude on there with 20x11 running a +11 offset squared crap. On a M37 dropped pretty low
CRV_33
Car: 2011 Infiniti M56x
I was told that 20x10.5 +25 all around would require alot of work in the front to get it to fit. I am sure 20x10.5 +45 all around could work as long as you don't have Akebono calipers. I pm'ed you earlier to see if you could confirm that the 20x10.5 +45 would work in the front.
twostep361
Car: qx80
I didn't get a pm,and i do have the Akebono calipers crap where i live were they have no idea or have product in stock to test fit.
well now i found some str racing 607 titanium 20x9 35et and 20x10.5 40et 850shipped on fleabay.
but searched and says if you Akebono calipers they won't clear. stuck again
but will be running spacers 20mm front and 5mm rear so on paper it should work.
which puts me at 15et upfront and 35et rear
want to use my stock 245 40 20s is the 245 to small for the 10.5? will it be big stretch?
iam thinking with 40 series its not gonna look that bad
putim37s
Car: 2012 M37S
twostep361 - I am unable to respond via PM due to lack of activity on this forum. HA.
I'm running a square setup, 22x10 +38. The fronts clear the Akebono's, and the wheel sits flush to the fender on a Eibach drop. I did place a 5MM spacer on the rear, and all wheels are wrapped with 265/30/22 tires.
It's a pretty conservative fitment, with minimal modification, or any clearance issues. The 265/30/22 tires are also still below the 3% diameter variance of the stock sport wheels/tires. Although, I will probably run 285/30/22 tires, the next time around. (Too much lip/rim exposure for me, and the tires do not have a rim protecting sidewall)
Should you run a staggered fitment, yes. I would, if I didn't have such a far work commute everyday. Replacing tires every year was getting old. (Been on some type of coilover, and aggressive fitment on my cars since '95!)
I did order the new Tanabe Sustec Pro Comfort-R coilovers, and hopefully will get installed this weekend. I can post fitment and clearance pics for you.
Not sure if this helps you in any way.
twostep361
Car: qx80
oh good news ,i want the 10" wide for the deeper concave look. Plus i get to rotate incase my camber is bad and can't adjust. I don't know yet haven't had a alignment.
Yes some pics with coilovers would help me very much. please get a fender to ground measurements.
also you think 285/30/22 will clear the front?
A big thanks brother.
CRV_33
the rolling diameter difference comes into play between the front and rear wheel/setup setup and not between your aftermarket vs stock wheel configuration.
Altered
twostep - A 245/40 on a 10.5 is pushing it, why not match a pair of 275/35 for the rear?
CRV_33 wrote:the rolling diameter difference comes into play between the front and rear wheel/setup setup and not between your aftermarket vs stock wheel configuration.
For the AWD system and ABS this may be true, but the speedometer will still be inaccurate.
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
Off topic, but Altered you have a strut bar on u 37?
Debonair
CRV_33 wrote:I was told that 20x10.5 +25 all around would require alot of work in the front to get it to fit. I am sure 20x10.5 +45 all around could work as long as you don't have Akebono calipers. I pm'ed you earlier to see if you could confirm that the 20x10.5 +45 would work in the front.
20x10.5 +45 with 275/35 R20 - they fit but just barely.
CRV_33
Ah man thanks for the follow up! :)
Altered
Glad to see they worked for you, I had to sell mine. The AWD models must have different knuckles in them, otherwise the V8 knuckles are different.
Debonair
For the record those are my rear wheels mounted on the front to check for clearance by CRV_33's request.
mexillis
Car: M45s
if those barely fit go with a lower offset if you "want" more clearance. how close was it to the fender?
Debonair
I did not lower the car to see. It was up in the air while I adjusted the ride height so I threw the rear wheel on the front to check clearance for CRV_33.
CRV_33
Debonair wrote:I did not lower the car to see. It was up in the air while I adjusted the ride height so I threw the rear wheel on the front to check clearance for CRV_33.
Hey I really appreciate that you tried it out for me and posted really good pics! :mike
Jeime71
Car: 2011 Infiniti M37x AWD
I'm tryna figure out if
20x9 front on 255/40/20
20x10.5 rear on 275/40/20
On my 2011 infiniti m37x awd
And I am waiting for bc racing coilovers
Any ideas on lower stance
Shanehsmp
Car: 2006 Infiniti M35x - Sold
2012 Infiniti M56x
2016 Infiniti QX70s
Jeime71 wrote:
Sun May 23, 2021 5:53 pm
It's generally not a good idea to go with a staggered fitment on AWD vehicles. If you must, you have to make sure the rolling diameter is the same between the back and front.
Using this calculator https://www.1010tires.com/Tools/Tire-Size-Calculator you would use a 275/35/20 to be equal to stock size. You can use it to figure out the equivalent to 255's if that's what you want to do. Is there a reason why you want to go 255 in front?
Jeime71
Just figured it would work any ideas
Jeime71
I'm getting 245/40/20 front
275/35/20 rear put on my xxr's right now
I'll post pics later today.
Jeime71
How do I upload pics
