elwesso wrote:
The FPR is regulated by engine vacuum... So, (correct if false) the FPR regulates based on engine vacuum... The base fuel pressure must be normal, as unless i am misunderstood, the FPR will regulate the same wether the pump is pumping 35 PSI or 40 PSI... Thats at least how I understand it.. I remember heraing that the FPRs dont fail.
So check the fuel pressure.
Quote »With the cats, the thing I was saying is how they melt... Remember AZskygod (sp?) and his terrible running 94... Im wondering, due to my rich running condition, this may a precursor to such a failure.....[/quote]It's not like you're dumping raw fuel all over the cats. (Besides, running rich lowers cylinder temps.) 18mpg is not a bad number, I rarely see that on my Q and I've never seen 20, even with a spotless intake and many new sensors.
Various gears aside, I think the bottom line is you're looking to get a solid 20mpg on a modified vehicle that was EPA-rated at 17/22 when brand new, with testing methods that are under scrutiny for possibly being too optimistic. The fact is, 10% mileage difference is well within the "noise" of all the variables that can affect mileage. Driving habits, weight, temperature, fuel quality, condition of various subsystems (intake, fuel, cylinder, etc), various sensors, etc. You can check everything to make sure they're all "in spec" and functional, but I guess what I'm saying is don't be surprised if they all are.
