Q45tech wrote:3.538 diff gear with 215/65 or 235/60/15 tires ~~ 333 rpm per 10 mph = 1980-2020 rpms @60 mph.4.083/3.538= 1.154 thus 1980 x 1.154= 2,285...........2,331 rpms nominal =2.308 rpms with 4.083@60mph.
Need to know what adaptive learn [100% +- 20%] is at a steady 60 mph and with injector opening time and fuel pressure and rpm we can calulate the error [whether the reduction is from driving faster than 55-60 mph or too much fuel being added].
Obviously if the adaptive learn is not 100% on both banks the AF ratio average is not 14.7AF..............even 105% yields 5% more fuel usage ....22 mpg/1.05=20.95 mpg..........110%=20 mpg
OK... let me analyze.....
First of all, I talked to Rob over the phone, and he said that if the speedo sensor was not changed, then it would be reading stock RPM and stock.. So even though its reading 2000 RPM, i would be going 2300 RPM... So I need ot verify I hvae the 4.08, and then we swap the speedo sensor.
So, assuming my fuel pressure is OK (still have yet to determine what could cause this, as its a new fuel pump!)
Dennis says that the difference in MPG at 60 MPH should be nominal, or at least what Im gathering.... He also says that the adapative learning (o2 sensors) would only produce 20% in either direction... o2 sensors arent very old (30k tops, still within working order). So whatever this is, it seems as if its beyond the computers control...
so the underlying question remains what would cause the fuel pump to run at a higher speed than normal . I will post pictures of how they had this fuel pump wired up before.... I dont know what would make it go, since the fuel pump is plugged right into the FPCU, as it should be..... The ECU, as far as I know, doesnt control it...
Thanks for the advice, sijoko.....
heres a couple other thoughts.....
the 94s have been known for the precat meltings.. If its been running rich, plus the fuel from the NOS, maybe its slowly eating those away.....
