I even tried that too. It's just getting it to start to hook the first 1.5ft, with my camber set like you're saying it made it even worse.. I'm almost thinking I need to raise the front end more to improve the angle of the rear end to make it want to under drive the car more.themadscientist wrote:Preload. I set my old Skyline for positive camber at rest so under acceleration it would sink into a flat stance for maximum traction.
themadscientist wrote:Nitto drag radials, under 300hp. With street tires it would spin, but my buddy who also had pretty much the same car could get great hookup. He had a much smoother launch technique than me, though. You are going to have to spend some time finding the right balance in your launch so you can bring the power up as quick as possible without breaking loose. The Q is not going to cooperate very much. If you lift the front it may help your launch, but you will then have an air plow causing drag and lifting weight off your steering wheels. Kind of retro.
flohtingPoint wrote:Getting proper tires is the first step. I do 2.0's with my FRC on Hoosier A6's ( http://scca.cdn.racersites.com/prod/a** ... 060_RT.pdf ), but these are not drag tires.
What's good for the goose isn't always good for the gander. Your buddy has a totally different car, this tire/tire size may not be good for your car. If you look at that list on my link, almost all the cars that dont have a class designation of "Street Touring [Whatever]" are on Hoosier A6's. Some run better 60' than me, some run worse. You cant compare two cars that are not identical. You also have to take into the consideration of how many runs are put on the tires, how many heat cycles, how old is the date-stamp on them, are you bagging them after each event to keep them fresh, etc.N/A Q45 wrote:flohtingPoint wrote:Getting proper tires is the first step. I do 2.0's with my FRC on Hoosier A6's ( http://scca.cdn.racersites.com/prod/a** ... 060_RT.pdf ), but these are not drag tires.
I run Nitto NT-555r DRs 275/50r15s.. my buddy that has the exact same tire can cut 1.8s with in his 69 mach1 but that's a lighter car.
themadscientist wrote:The tires are not at issue here. He gets 100% contact patch all the time, yours is probably 90% at best, growing and shrinking as your suspension moves up and down. I think you have good tires, you just need to get that suspension under control so they can work. I'm a newb when it comes to suspension setting; it's a complex art, but I would get some stiffer springs with harder shocks and adjustable upper links to dial in the camber. I think it's the excessive movement and changing camber and contact patch that's screwing you. get the range of motion reduced and make movement more controlled so it can absorb strong shocks rather than break loose, but otherwise maintain a controlled motion.
WDRacing wrote:Just wondering why you went with 275/50's and not 275/60's? I always used BFG or MT ET streets. The 60 series might give you that extra "squat" you're looking for.
Without knowing anything about the tire history (ie how old they are, how much they've been abused, how many heat cycles have been through them), I find it impossible to rule them out. Tires are the most important part of any competition vehicle (obviously you need the thing to be running and such), all the HP and suspension mods cannot cover up bad tires. We have classes in the SCCA where you're allowed to do exhaust/suspension/ecu mods/intake/lightening but you're limited to 140+ treadwear tires, and the pointy end of these classes, Street Touring R (consisting of S2000's and NC Miata's), is slower than it's respective Stock equivalent class (B-Stock/C-Stock which consists of the S2000's and NC Miata's) because Stock gets to run on R-Compounds.themadscientist wrote:The tires are not at issue here. He gets 100% contact patch all the time, yours is probably 90% at best, growing and shrinking as your suspension moves up and down. I think you have good tires, you just need to get that suspension under control so they can work. I'm a newb when it comes to suspension setting; it's a complex art, but I would get some stiffer springs with harder shocks and adjustable upper links to dial in the camber. I think it's the excessive movement and changing camber and contact patch that's screwing you. get the range of motion reduced and make movement more controlled so it can absorb strong shocks rather than break loose, but otherwise maintain a controlled motion.
Lol I think you need more tires!flohtingPoint wrote:Without knowing anything about the tire history (ie how old they are, how much they've been abused, how many heat cycles have been through them), I find it impossible to rule them out. Tires are the most important part of any competition vehicle (obviously you need the thing to be running and such), all the HP and suspension mods cannot cover up bad tires. We have classes in the SCCA where you're allowed to do exhaust/suspension/ecu mods/intake/lightening but you're limited to 140+ treadwear tires, and the pointy end of these classes, Street Touring R (consisting of S2000's and NC Miata's), is slower than it's respective Stock equivalent class (B-Stock/C-Stock which consists of the S2000's and NC Miata's) because Stock gets to run on R-Compounds.themadscientist wrote:The tires are not at issue here. He gets 100% contact patch all the time, yours is probably 90% at best, growing and shrinking as your suspension moves up and down. I think you have good tires, you just need to get that suspension under control so they can work. I'm a newb when it comes to suspension setting; it's a complex art, but I would get some stiffer springs with harder shocks and adjustable upper links to dial in the camber. I think it's the excessive movement and changing camber and contact patch that's screwing you. get the range of motion reduced and make movement more controlled so it can absorb strong shocks rather than break loose, but otherwise maintain a controlled motion.
Below is an image of RT's and 60' times from the New Jersey Pro Solo (drag launch followed by autocross course). All the runs were done on the same type of tires (Hoosier A6, 295/17 front, 315/18), but I had two sets of tires; one set was from 2010, the other set was from 2012. The sheet got a bit messed up by the formatting, but all the same, the info is right there.
The runs in yellow are on the tires from 2010; 2.4 cold, 2.2 best warm for 60'. The tires in red are from 2012; 2.4/2.2 cold 1.9 best for 60'. Heat cycles, age, wear greatly affect tire performance. I was running the 2010 tires to get a dial in on the Vette for the surface we were at, then bolted on the 2012 tires when it was time to party.
Note* Yes my RT's are a**, I hosed the tree every run =P Same clutch drop, just bad light timing. We normally have LED trees, this was an actual bulb, meaning you kinda had to pre-drop after the 2nd light as the light comes on at a different rate. I jacked that up nearly every run =P
I would recommend getting some proper tires and a set of rear wheels so you can change them at the track. The tires will fit fine in your back seat, you can take them to the track with no issues. When you're not running on them, wrap them in pallet wrap and store them somewhere they wont get super cold or heat cycled by the elements.
Note* One set is unwrapped, I was in the process of wrapping them at the time of the photo. Took the picture for reminding folks to write letters pertaining a proposal in the SCCA to remove r-compounds from stock.
Lol I think some of the civics around here do that because they just keep spinning and think they are quick while running 16secthemadscientist wrote:Sort of the reverse from the drifters where they grab crappy tires and throw them on the roof to bake.
flohtingPoint wrote:I do a LOT of racing =) I just got back from Lincoln, Nebraska where I was at Spring Nationals, getting my dial in on the Vette for the National Championship. My Vette logged somewhere around 50 or so runs there in competition and test and tune.
I would get whatever the best tire you're allowed, no sense leaving time on the table. Grab the best tire in your budget, get a set of rear wheels for it (you can get spun steelies for very cheap in whatever backspacing you want, look up race steelies and you'll find TONS of companies that will make them for very cheap), and then tune from there. If there are no rules against tire compound (or bias/radial allotments), bolt up the good stuff and go racing!
I could probably find a tenth or so if I softened the rear a bit more, if I swapped tires or bias-ply, I could probably find another tenth, as A6's aren't really for drag racing.N/A Q45 wrote:I would expect your car to run much quicker 60ft time if if was set up for only drags though FlohtingPoint.?
And WDRacing lol if I were able to use that stuff on the track there would probably be a fight behind me for my lane![]()
I think I might just have to pull some lowend power and put it up top until I get some slicks. Going to give this setup one more try here on the 14th hopefully my new bushings come in and I get them in before.
