flohtingPoint wrote:The more rear weight transfer you get, the more pressure there is on the tires, the more force there is pushing them to the ground, the more they will hook up. It works not just for drag, but for trying to find traction on any RWD car. We utilize a very thick/solid front swaybar to get even more cross-weight transfer when cornering to load the outside rear tire. When the car isn't turning enough, we need to dial in more slip, so we will increase tire pressures and bump the damping up.
I agree but there's also power loss to take into consideration, it takes X-to move Y-
Force being X- and Suspension being Y-. When the suspension is being squatted that is power that could be put into moving the cars chassis forward instead of down.
Good ole physics, can be interesting.
