the differences won't be enough to make one better than the other.nihon wrote:what are the pros and cons.
Up front cost for the RB is less, but once you start modding the RB, the SR would have been the cheaper option. SR parts tend to be cheaper and more readily available, in general.nihon wrote:i dont want to spend more money on an sr
RB20 is more expensive than the SR20?Or are you implying the SR20 is heavier than the RB20?Space Monkey wrote:Heavier more costly mortor for same power output FTL.
Lot of people do here. I've actually seen more RB20's then the SR20's here.Bumnah wrote:....
Frankly I don't know why anyone would put an RB20 in their 240sx.
I think it's cause then they can brag about their base model Skyline engines or something.
Im actually amazed its still open.The Iron vs Aluminium was just a guise for SR vs RB, either the mods let it slide or they havent seen it yet.Either way, i think we might as well milk the freeposts while we can.fender-startocaster wrote:i like this debate.
all good opinions an iron block is way heavy wich=power to wait ratio.. and alu. is light again= power to wait ratio.. but as stated a iron block can handle way more heat than alu. so its your judgement call lol.. but ka has tourqe.....Nali wrote:
More RB20s than SRs
My vote goes RB20 for low HP goals(i.e stock).SR20 for higher HP goalsand CA18 for the win
More RB20s than SRs
sad but true.. but alot of tourqe.. but as you said much support for the ka.Chris28 wrote:KA. Lots of aftermarket support, iron block.
USDM hate is still holding out in a few pockets of resistance across the countryasoomal wrote:Edit: Oh and also, I dunno why, but no one likes the KA around here. I have yet to see a KA-T.
fastass wrote: but ka has tourqe.....
Do you actually believe Torque is spelt like that?fastass wrote:but alot of tourqe
Now look here foo, if you didnt come to argue then what reason are we having this conversation?fastass wrote:quite a lot, but i didnt come here to argue..
hahaha i have no earthly idea..Nali wrote:Now look here foo, if you didnt come to argue then what reason are we having this conversation?
Good comparison. But RB20's and RB25's also utilize hydraulics lifters. But still much better than a hydraulic lifter and rocker setup.Didderson wrote:OP, you should be more concerned about the mechanics of the SR20 versus the RB20 when selecting an engine for its reliability. Take note of the redline, stroke and bore, and valve-train design.
If you're a drifter who's going to beat the piss out of his car, I'd actually suggest the rb20 because of the valvetrain cam on bucket design. Hydraulic lifters do fail, and valve float blah blah blah.Timing belts suck though :P I mean changing them sucks. RB's have timing belts, not chains.
RB:Cam on bucket valve train.Bore x stroke mm: 78.0 x 69.7oem redline =7600. I'm sure you can increase that reliably with much less effort and money than us SR guys.Also, 6 cylinders will fire much smoother at the same RPM as a 4 cylinder engine, IMO making it more reliable.I could argue that the increased cylinders also will provide more torqueYou can always bore out your RB when you blow it up to rb25 status :P I'm serious, this is the ONLY reason why I think people buy an RB20.The difference in weight bias because the engine is heavier/more far forward is up to you. Think of other reasons before weight if you're thinkin reliability/robustness
SR:Most people forget aluminum blocks are sleeved with iron/steel anyway. What I mean is the piston travels inside a steel cylinder, so yeah.OEM Redline: 7500. SR has 86mm x 86mm bore and strokeChain driven timing system (IMO basically maintenance free granted you take the chain guide off) But arguably chains vs belts add rotational weight :P
The only drawback to an sr20 is the rocker arm and hydraulic lifter design. It's been extremely reliable for me, but I have only hit 7500 rpm once or twice. Aluminum is more beautiful (to me) than iron :PTechnically you could argue it wears quicker than steel because of density but that's what crank bearings are for.
I'll stop before this gets too long, but you should choose your engine based on the mechanical aspects of it rather than the metal it's constructed of
You might want to consider the RB's little brother, the CA:http://www.driftcentral.com/fo...=1379
Dangit, all this text for a 1 post new guy. He better read this lol.
