Because only the NGK PFRG Laser Cut Platinums were designed for the engine. They are optimal, everything else is a degradation, many are dangerous.TXCumtrensh wrote:I dont see why iridiums would be bad
As long as you stay away from Bosch, and stay with NGK's.. you will be fine.. Id just go to the dealer for plugs
Could you please elaborate as to why different brand plugs would be dangerous?The engines 10.xx compression ratio isn't very high. The timing isn't exotic, and the heads are a pretty normal hemispherical design with 4 valves.maxnix wrote:Because only the NGK PFRG Laser Cut Platinums were designed for the engine. They are optimal, everything else is a degradation, many are dangerous.
There are some horror stories here about less-than-optimal plugs breaking, falling in, and scoring the walls!nimbyfaygo wrote:Could you please elaborate as to why different brand plugs would be dangerous?The engines 10.xx compression ratio isn't very high. The timing isn't exotic, and the heads are a pretty normal hemispherical design with 4 valves.
Actually, they are a pent roof design.nimbyfaygo wrote: the heads are a pretty normal hemispherical design with 4 valves.
Plugs are not your problem most likely injector issue. We go threw this same conversation about plugs and U will always get the same answers. Most will say stick to OEM NGK Platinum's and to stay away from BOSCH which is true. The plugs that U have in your car would most likely be the best replacement to the OEM plugs but were not avail. at the time the VH45DE was produced. I have ran the NGK Iridium Plugs with no problems for the last few years in 2 of my Q's and 4 others that I have worked on. Both are the same plug just that one has the Iridium tip and the other Platinum. Iridium is a harder material than Platnium and are suppose to be good for 100,000 miles under normal driving conditions with normal maintenance. Look somewhere else for your engine problem because it's not your plugs.Some people damage their coil packs or their coil harness during R&R of the plugs and this will cause a mis-fire and then they are quick to blame the plugs! Also always check your gap because they can be dropped and gap will be wrong even though they are said to be pre-gaped.ismael-robert wrote:Hey guys I put iridium plugs in my q45 a while back and I honestly don't remember how long after it was, but my idle is bad now. I've read that our cars require a certain plug, but on the ngk website it says there is an iridium substitute. So is it okay to use iridium substitutes in our cars or not? I have tried cleaning the throttle body and maf sensor, replaced air filter and fuel filter and one other cheap little part (I can't think of the name right now) and several types of fuel injector cleaner.
Pretty sure those are heat range "5", which IIRC is what stock should have been ... though not sure on CA emissions carsFalkdesigns wrote:It's been a few years now, but I'm pretty sure they were the same range. It doesn't say on NGK.com but it's this part, BKR5EIX-11.
If I remember correctly they have the exact same as OEM and lower and higher also avail. depending on your application need!The only difference is the tip is made of Iridium. Variety is a good thing because everyone can't benefit from the same identical plug when living in different environments. Plus all VH45DE were created equal from the factory but, if U put 3 different engines on the DYNO U will get 3 different Dyno readings 15 years later. With this in mind an engine that has 40,000 miles will be able to get away with a factory plug where a engine with over 200,000 miles and leaking valve cover seals require a different heat range to prevent fouling. NGK makes R5, R6,R7,R8,R9,R10,and R11's. Variety is the spice of life!elwesso wrote:Were the ones you put in the same heat range as the OEM?
