I returned the new ones. Now waiting for 8 new replacements. (22448-3H000)
without being able to get a code.
I just cant seem to wrap my head around the fact it runs so well whenever it has a fuel additive. whether in the tank or the intake. also runs great when its just started.
If indeed it is the coil paks, then it should have ran well with the new ones. Coils have to work harder in lean conditions,
the only thing i can think of is that the additive raises the octane level enough to compensate for the lack of spark energy.
in the morning i drive 1 mile, park, 5 minutes it sits. i jump back in it runs like crap(stumbling /surging) lack of acceleration till about 2k-3k rpm. drive back home. It sits a couple hours. starts drives great for miles on the freeway, then as soon as i get off the freeway. Back to crappy.
so...is it running rich (fuel injector leaking) thus runs bad till the excess fuel is burned off. or is it running lean.
If i get a chance today i will be installing a fuel pressure gauge.
i will also be making a coil pak/ misfire tester. Using spark plug wires and a timing light.
The OBD2 scanner ive ordered is BAFX Products 34t5 Bluetooth OBDII Scan Tool
On aside note.
If the coolant temp. sensor is disconnected will it run in limp mode or ?
I want to disconnect it and see if the drivablity improves with the ECU not being able to detect the coolant temp.
Thanks for all the assistance and help, Cheers
