Iowa NICO meet.
Including ND, SD, NE, KS, OK, MN, IA, MO, and WI
float_6969
Yea, I learned that the hard way. My last 240 had a great suspension, but I didn't realize how much more important it was than power till I got a car with power and now can't keep it on the ground! I would definatly put suspension before power if I do it again.
E Dogg
Car: 1997 M3 sedan
1988 TII RX-7 10th AE
1990 Ford Bronco XLT
nothin better than learning about that as you find out how fast your SR puts your car in the ditch
edit: i would put LSD above the suspension though, i like driving my 240 better than a SR equipped one with no lsd
float_6969
I already have LSD, but I COMPLETELY agree. I think it should be EVERY 240 owners FIRST mod.
PS - I should say that I HAD and LSD, I think I've managed to blow it. But since it was a stock VLSD w/about 160K miles on it, I'm not complaining.
E Dogg
Car: 1997 M3 sedan
mine has 150 and works like a champ, mabye i shoudl cherish it while it lives. Did u ever change ur diff fluid on ur car?
574-240sx
Car: Nissans, Toyotas, Subaru
An Iowa meet would be great. The spring/early summer would be a perfect time. I have to wait till schools out. Maybe I'll have time to get my next 240 running or I will have to bring the maxima. Nick
float_6969
E dogg - amsoil in the transmission and rearend, mobil 1 in the motor
Altiman94
Car: 1989 Nissan 240SX
I've never changed my diff oil sinec I've had it. I'll bet it's never been changed. Should I change it?
float_6969
if your car is an 89, YES!!! It's supposed to have gotten changed every 60K miles. I'll bet your about 2 changes overdue!
Altiman94
more than likely.
float_6969
well get it changed man!!! Hehehe
E Dogg
Car: 1997 M3 sedan
i think my lsd is still ok b/c it only has to deal with one hundred-some horse power if i had more power than that im thinking it might need replaced
float_6969
Well drifting and bad weather (snow) is hard on them.
E Dogg
Car: 1997 M3 sedan
well it hasnt dealt with any of that, yet
float_6969
Hehehe, just wait till it does! I was reading an article about the SC 350Z and they tore up the stock LSD the first time they took it out to drift it. I guess they stuck some big fat sticky tires on the back and when they went to do a burnout it just shredded the viscous coupler (basically what happened to mine) and so they replaced it w/a NISMO unit. (which is what I'm going to replace mine with)
E Dogg
Car: 1997 M3 sedan
well i dont have to worry about fat or sticky tires, i have stock sized 195/60-15's on with little to no tread
float_6969
Well get some 18X10's on there! JK. That would be a little excessive..
RefriedNismo240
im a little late on this but Im there man. Give me a date, Cedar Rapids is just about 2 hours away.
E Dogg
Car: 1997 M3 sedan
i can balry spin the ones i have.... i still have lots of tuning to do, she takes 10 sec to hit 60 with intake weight reduction and somewhat free flowing exhaust
Altiman94
sounds like a lil tuning is needed in your case
E Dogg
Car: 1997 M3 sedan
are u familiar with tuning 240's? i could use some input
float_6969
have you done things like changed the plugs, plug wires, cap, rotor, and fuel filter? Those things will make more of a difference than you think.
Altiman94
Timing, I'll almost gurantee your timing is severely retarded. Mine felt sluggish getting it back fromt eh shop because they didn't set the timing right.
E Dogg
Car: 1997 M3 sedan
im at 20 below tdc, correct timing right. Keep in mind my ka is out of a 95
Altiman94
are you positive its at 20* btdc
E Dogg
Car: 1997 M3 sedan
yeah it is, accodring to my timing light...
Altiman94
alright, well check injectors and all your vacuum lines. I'd also check the ecu itself. Check all engine grounds and the maf tolerances
Altiman94
also, have you checked the engines compression and/or done a leakdown test?
juxaguy
Car: 1996 240sx SE
I'm intrested. I could make it depending on my schedule in the spring.
goldenchild
Car: 90 Nissan 240SX KA24E-t go bye bye, gotta another in the works
If theres a meet Ill be there. I live in n.d. and Im willing to travel
Altiman94
been to n.d. once. Very boring. Just like Iowa.
Return to “Midwest Region”
