Internet = Wholesale OEM
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
okis14
dantech wrote:There may be an aftermarket bearing available. Shot me an email and I'll send you a link.
I sent an email through NICO but there was some kind of error message after I sent it at the top of the page. No sure if it went through or not but if it didn't could you send me the link to [email protected]?
MidwayParts
Vendor
Car: 2011 Titan
amolao wrote:Hi Dan!!
Hey quick question;
How much for the window seals on 240SX 1989, Im referring to the seal on passenger and driver doors, it kind of wraps around the corner section where the sideview mirrors are attached and also serves as a guide for the window when is going up ,,,,,I hope Ive been clear enough on my description. Mine are all cracked up, Damn Alabama sun!!:(
thanks, ....
That was a pretty good description, but I think we're gonna need pictures. I think what your looking for is this #80830 and #80831. They are $55.05 each
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Okie-dokie....hey how about a timing chain kit?? for 1989 240SX and whats included on the kit??? If you dont sell a kit then I need the following:
Qnty: 1 Part#: 13028-8B000 Description: chain Qnty: 1 Part#: 13070-40f06 Description: tensioner
Qnty: 1 Part#: 13085-40F10 Description: slackl side guide
Qnty: 1 Part#: 13075-40F10 Description: bolt for s guide Qnty: 1 Part#: 13091-40F15Description: tension side guide Qnty: 1 Part#: 13510-53F10 Description: frt crank seal Qnty: 1 Part#: 15066-5E500 Description: frt cover seal
+ Shipping (all parts):
Please give me the indivdual prices of each part...... thanks:help
MidwayParts
Vendor
Car: 2011 Titan
Qnty: 1 Part#: 13028-8B000 Description: chain $37.58
Qnty: 1 Part#: 13070-40f06 $49.90Description: tensioner
Qnty: 1 Part#: 13085-40F10 $8.76Description: slackl side guide
Qnty: 1 Part#: 13075-40F10 $1.48Description: bolt for s guide
Qnty: 1 Part#: 13091-40F15Description: tension side guide $8.92
Qnty: 1 Part#: 13510-53F10 (actually a 13510-53J10) $4.72 Description: frt crank seal
Qnty: 1 Part#: 15066-5E500 $3.41Description: frt cover seal
+ Shipping (all parts): $13.93
One free Nissan hat: $priceless
:patriot
Red240sx95
do you have radio trim for 95. [email protected]
Red240sx95
MidwayParts
Vendor
Car: 2011 Titan
Red240sx95 wrote:do you have radio trim for 95. [email protected]
youve got mail.
http://www.trademotion.com/par...gid=2
:thumbup
JustinStrife
Car: '99 FRC. 402, Vortech T-Trim @ 12psi = 706rwhp/621rwtq
I need the passenger side headlight assembly. I gave up trying to navigate your site. ^_^ It's not for dumbies. Could you e-mail me @ [email protected] with a quote? I'd greatly appreciate it.
Will
MidwayParts
Vendor
Car: 2011 Titan
JustinStrife wrote:I need the passenger side headlight assembly. I gave up trying to navigate your site. ^_^ It's not for dumbies. Could you e-mail me @ [email protected] with a quote? I'd greatly appreciate it.
Will
Sorry bout the site. Here, I found what you need. The headlight is http://www.trademotion.com/par...gid=2
and the side marker is
Hope this helps. Ill be checking my email this weekend and if you want, you can order online or just email me.
JustinStrife
I've just placed an online order on the headlight assembly. I'll have to hold off on the side marker as I have other things taking up my funds at the moment :*(
MidwayParts
Vendor
Car: 2011 Titan
Thanks a bunch. Ill get that handled.
ph34r
Hey Dan, can I get a quote for a drivers side fender for a 91 240? Thanks
got_boost702
Car: racing, cars, snowboarding
how much for a speed sensor on a 95-98 240sx with a 5-speed.
BadMojo
Car: 2007 Mazdaspeed 3
Dan,
1993 Nissan 240SX fastback
Engine Undercover (with hardware if possible)
Oil Pressure Sender
That little plate that covers the spot where the power mirror switch would be (if I had power mirrors)...near the cigarette lighter.
The little clips that hold the rear package shelf in place.
Sorry for the crappy descriptions of the interior pieces.
Thanks,
Brad
MidwayParts
Vendor
Car: 2011 Titan
ph34r wrote:Hey Dan, can I get a quote for a drivers side fender for a 91 240? Thanks
You bet. Its $262.58 and you can order it here. Thanks
MidwayParts
Vendor
Car: 2011 Titan
got_boost702 wrote:how much for a speed sensor on a 95-98 240sx with a 5-speed.
I can get that. Its $99.77 and you can order it here:
http://www.trademotion.com/par...gid=1
Let me know if I can help.
MidwayParts
Vendor
Car: 2011 Titan
BadMojo wrote:Dan,
Oil Pressure Sender
Thanks,
Brad
No problem. I think I got you covered.
That engine cover doesnt come with any hardware. All that my catalog shows is some bolts and speed nuts. Those shouldnt be too hard to come by from a hardware store. If you want, I can always round them up for you also.
The cover is $61.86 and can be found herehttp://www.trademotion.com/par...gid=2
The oil pressure sensor is $9.75 and is here:http://www.trademotion.com/par...gid=1
The mirror switch cover is $3.28 (68493-01f02)The retainers are $.37 each (02809-19300)
You can just add those last two to the order if you order online. I will make sure they get on the order. Just make sure to specify the quantity.
Thanks. Let me know if I can help.
Nitrus0nous
Dan,
I want to order
The master is $74.67the tubes and hose are $11.21 - $10.00 - $12.58the slave is $33.96the upper boot $4.51the lower boot is $30.89
also, manual transmission flywheel bolts (i understand they're longer than a/t bolts?)
Nitrus0nous
89 240sx by the way
throwout bearing and pilot bushing as well.. [email protected] is my email
BadMojo
dantech wrote:The cover is $61.86 and can be found herehttp://www.trademotion.com/par...gid=2
Thanks, Dan. I ordered the sensor, but I'm going to hold off on the engine under cover for now. I also put the retainers, the switch cover and some washers for the oil drain plug in the "additional text" part of the order form. You can just adjust the shipping charges to whatever is appropriate for ground shipping of all of those extra items.
Thanks!
MidwayParts
Vendor
Car: 2011 Titan
BadMojo wrote:Thanks, Dan. I ordered the sensor, but I'm going to hold off on the engine under cover for now. I also put the retainers, the switch cover and some washers for the oil drain plug in the "additional text" part of the order form. You can just adjust the shipping charges to whatever is appropriate for ground shipping of all of those extra items.
Thanks!
Thanks for the order, PA. You'll be getting about three confirmation emails letting you know how things are going. If you have any questions, please dont hesitate to call. Thanks again.
MidwayParts
Vendor
Car: 2011 Titan
Nitrus0nous wrote:Dan,
I want to order
Handled. Thanks a bunch. I sent you an email on the details of the final order. Call me with any questions. Thanks again.
DbD
I don't want to be a bother, but I am just curious as to the price of 90 300zx non-turbo calipers.
thanks, and sorry for taking up your time,DbD
DbD
Oh an also do they come with a warantee?
MidwayParts
Vendor
Car: 2011 Titan
DbD wrote:I don't want to be a bother, but I am just curious as to the price of 90 300zx non-turbo calipers.
No problem. You ask as many questions as you want. Thats what Im here for.
I dont think you can get those calipers anymore. I found a price on a left one ($357.91) but cant on a right. That probably means they are both not available.
Sorry:(
firekirin
i need a knock sensor for my sr20det... which is from a 93-99 sentra s-er how much for one thx?
JustinStrife
Se-r's didn't have SR20DET's unless you put one in or you don't live in U.S.?
I thought they just had SR20DE's but not turbos
firekirin
that is true i just need a knock sensor for my sr20det that can be taken from a 93-99 sentra s-er which has the sr20de when everything is basically the same
Touchdown038
Car: Computers, cars, sports
How much are intake and exhaust valves for a 240 with the KA24E?
MidwayParts
Vendor
Car: 2011 Titan
firekirin wrote:that is true i just need a knock sensor for my sr20det that can be taken from a 93-99 sentra s-er which has the sr20de when everything is basically the same
Here you go. Let me know if I can help.http://www.trademotion.com/par...gid=1
Return to “Advertisers' Marketplace!”
