Shift__BODOM wrote:The same thing happened to me. It wouldn't charge until I gave it gas. I thought it was the belt, and when I was poking around, I decided to mess with some of the connectors. I wiggled a connector on the side of the alt and bang, insta-charge. Turns out it wasn't seating properly or something (tab broken probably) and coming loose, and I guess the vibrations of the motor revving (about 2000RPM, not much) happened to wiggle the connector. I since pushed it down as hard as possible and no problems.
Check the connector if you haven't. If it doesn't fix the prob, you might need a new alt.
I had the alternator out two weeks ago, everything was tight coming out, and I double checked everything going back in. I was having the issue before, and after alt removal.
Vegascorbin wrote:The problem is in the alternator. The voltage regulator is internal to the Alternator and is not getting properly excited at idle. Do you still have the original panel bulb/meter in the circuit? it is required for the charging circut to properly function. If yo hav echanged it from original then put it back to orginal and re-test. I wouold just replace the Alt. if it was me. IF you are short of funds then just goose the engine until it starts charging. That will work for awhile but you will end up changing the alternator sooner or later anyway.
One other thought. What RPM are you idleing at? If your ide is set too low them bump it up first then re-test.
Are you sure the volt reg is internal? Some are external, or are integrated into the ECU.
Its not that Im super low on funds, its just that I dont like throwing parts at a problem, hoping it be solved.
The engine Idles at 850 when warmed up, as it has for the last three years.
