RicerX »
https://forums.nicoclub.com/ricerx-u125542.html
Wed Mar 09, 2011 2:09 pm
ECU - Engine Computer Unit.
Resetting it likely isn't what you need to do. The light will blink if the battery is low (even if the remote you're using seems to work perfectly, the car will detect a weaker than optimal signal, causing the light to blink.)
For $3, I'd start with a new battery in the key. If that doesn't yield a different result, return to the dealership at which you got the key programmed and have them troubleshoot.
