finding a shop to fab a custom intake manifold isn't going to be easy. and i truely don't believe 5 to 7 hundred is a very accurate price when including custom fabrication + installation. also, the part is not going to be quality and good luck getting the shop to back their work should it cause damage to something.TheBourneAltimatum wrote:yeah IM's can add some good amount of horsepower, and this is a not hard to get mod..look around sactown and you should be able to find a shop who will make one for you...you can probably get one done for about $500-$700...it'll be worth every penny
No you won't. My turbo runs the stock ECU @ 6 psi. The ECU handles every bit of it, and retains a flat a/f ratio across the rpm range. I changed the injectors to 440cc's, but thats because we only wanted to be running about a 70% load. You could run a 70% load on the stock injectors and still not lean out with just an Intake ManifoldCarcass wrote:If you change the IM & Exhaust, you'll have to alter the fuel map or increase fuel somehow, otherwise you'll have an over-lean condition. I don't know if the A/C ECU can automatically compensate for a change that big.
