SSSCA18DET »
https://forums.nicoclub.com/sssca18det-u17131.html
Sun Jun 27, 2004 12:25 am
I've actually just done this mod (today), the butterfly's are pretty easy to remove. To remove them, I found it next to impossible to unscrew, I ended up drilling them off the rod, and then the rod slid straight out.
Over the the drill press, open the holes on the end of each 'half' of the manifold, and then tap for a 1/8 BSP plug. Nice and easy.
Might as well match port whilst its all apart.
I've seen the pics of the 4 port heads, I recall having seen those in Australia at some point (I'm in Melbourne).
From memory they were on an early CA18det (FWD) from a pintara (non intercooler version).
Not much use for RWD but though you may be interested.
