Intake Manifold Butterflies
cortina-mk1
Car: GT-R Skyline, MK1 Cortina's
have you had your manifold on the flow bench ?
float_6969
thats what I want to do. I wish we could get one of our UK guys to put one of thier 4 port heads on the flow bench so we could have some numbers to compare. I'm going to do mine in the next month or so...
SSSCA18DET
Not yet, dont think I will.
It's really not that much of a major mod, just some tidying up.
If I went to town on them, then I think I'd consider it.
Anyway, I've found each port on the manifold takes about an hour to get right.
Anyone else got any tips or pics??
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
not really, but would you kill me if i copied you?
- tim
minutericesentra
Car: 96 Z32, 06 R51
SSSCA18DET wrote: I've found each port on the manifold takes about an hour to get right.
That means it'll take half the time with a 4 port than a 8 port right? j/k :D
SSSCA18DET
Wouldn't that be nice.
All up I estimate the 8 port manifold will take about 16 hours to do properley. As the 2 part manifold has so many ports to clean up.
I too would be interested to see flow results of a 4 port.
fanta
I'm simply shaving down any pronounced ridges and cleaning up the "Y." Take your time, don't work for a mirror finish on the intake side :D
SSSCA18DET
I'm not going for a mirror finish, just match porting the manifolds to each other and then to the head. Just takes time to get it right.
cortina-mk1
i have flow bench figures on a lot of CA189det intake and exhaust areas
but the flow bench time cost me $$$$ so im reluctant to give away info fer free :) i hate saying that BTW..
if you can understand my reasons ... geez i hope you all can :)
SSSCA18DET
May I ask where the gains were to be had????
cortina-mk1
@ SSSCA18DET :) the work you are doing is certainly heading in the right direction .. :)
slw240sx
Car: 1990 Ca18det 240sx Hatch
with a big enough turbo and some cams the flow on the intake and head are goin to only add up to fractions of HP. there are better yeilding mods for the money that this tedious non needed work will cost.
float_6969
cortina-mk1 wrote:i have flow bench figures on a lot of CA189det intake and exhaust areas
You suck.... JK! I kinda understand. Are the #'s for the 8 port head? I've got a friend with one, so I can have it done for free, so I'm not too worried about it, but I'd be willing to hand over a few bucks to see the results on the 4 port...
boost_boy
Quote »with a big enough turbo and some cams the flow on the intake and head are goin to only add up to fractions of HP. there are better yeilding mods for the money that this tedious non needed work will cost.[/quote] I concur with Jon on this one. A whole lot of hoop-la for not a whole lot in return.
Dee
SSSCA18DET
The car is off the road whilst a new exhaust manifold is coming from OS, dont have much to do on the car other than this and put some head studs in. Other than that the rest of the engine has already been done. It runs a GT25 turbo, some slightly larger cams, head porting, large FMIC, bigger injectors, throttle body, internals etc.
This is a low cost thing, although time consuming that will hopefully improve the overall engines breathing and output. I'm not aiming for 40hp or anything, but 5-10 would be nice. It was cheap, time consuming, however I have a bit of spare time before the rest of the bits I've ordered come together.
SSSCA18DET
BTW - If anyone does have any flow bench results on the 8 port head (STOCK) and you're happy to share, email [email protected]
I'm thinking of getting mine done after I've reasssembled it for a comparison.
Cheers
Simon
