Magnet 2112 wrote:Thanks all, good links. I think I will buy a torque wrench for the install. Now for the dumb questions, what does this mod do to the warranty and do you use sealant on the spacer as bean suggested? I saw another thread contraindicating the sealant. And do you think this mod is worth it
It does nothing to the warranty, unless they can prove that the spacer itself, caused a malfunction.
As far as the RTV sealant, I used a very thin line. If you put it on too thick, you could potentially have some problems, but it is unlikely. If you use it really thin, it just provides a great seal between the plenum and the spacer. I used it on both sides of the spacer.
Also, think about it like this, if you have any difference in thickness in the spacer, or if the plenum isn't perfect, the RTV will fill in those spaces, and make a perfect seal.
I will strees the fact that a very thin bead should be used. Overkill is not beneficial.
