Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu May 01, 2008 9:32 am
Cody, S13 chassis have the fuel pump relay in the engine compartment fuse box. Putting it in the driver's kick panel is an S14 thing.
sean, to test if you have a good ground for your relay, do this.
1- pull the relay out2- turn the car to 'on'3- take a test light and apply it across the two pin receivers that are furthest apart.4- if that doesn't light up, then test to make sure you have a good power supply. You want the one labelled in my above picture as B/W. If you have power there, you've narrowed it down to either a bad ECU or bad wiring.
What you can do, then, is turn the car off, replace the relay, and remove the ECU.
If you go by my picture, Pin 104 is the B/P wire. If you turn the car back on, attach your test light to a good ground source, you should have power across that terminal when you test it.
If you do get power, then you have a bad ECU. If you don't, then you know something in the harness is effed up. I would start with usual suspects before I go cutting and soldering. Make sure that the EFI -> Chassis harness plug by the battery is making good connection. The Black/Pink wire passes through there and if it's not making good contact, it will act like a bad ground.
If you can test that as a good connection, then you need to isolate where the potential problem is. Is it in the EFI harness or the chassis harness? A continuity tester will be your friend. You can test between the relay plug and the chassis connector as well as the EFI side of that connector and the ECU plug. Depending where it is, repair it and move on.
Hopefully this is just a bad ECU. 9/10 when I see issues like this crop up, it turns out to be ECU related.
