seanman »
https://forums.nicoclub.com/seanman-u45341.html
Tue Apr 29, 2008 5:57 pm
ok i did some research in my fsm on the fuel pump control. the ecu relays info to the fuel pump, which depending on that info, it will decide if the pump should start priming. The ecu decides from 4 main factors: camshaft position sensor, mass air flow sensor, engine coolant temp sensor, and the ignition switch. Now if all that checks out then the fuel pump relay will do its job and turn on the pump. Im not saying all this to sound smart, just info i found. i think this could help with my diagnosis; im pretty sure my CAS is fine, coolant temp is good and i know my ignition works. So that leaves the mass air flow; i think when i put too much fuel through the pressure regulator and it stalled, that somehow my ecu tried to fix it immediately and in doing so did something to my MAF. What do you guys think?
