hokiruu »
https://forums.nicoclub.com/hokiruu-u3429.html
Fri Aug 08, 2003 6:01 pm
I don't know how helpful this is, but here's what I did on my s14. First of all, toss that windshield squirter reservoir. FMIC is pretty much a full race type mod as far as compatibility with stock parts goes - it's generally not compatible at all. My Blitz LM kit came with a diagram measuring the center of the hole from the top (firewalla side) and right edge of your tray. To check your measurement, just attach the coldpipe to the TB and see where it goes. Then attach the cold pipe from the core going up to underneath the battery tray. Between these two pipes, you should be able to see about where the hole needs to be cut. Use a marker to mark where the piping walls are on your battery tray. Then find the center of a circle between these points. Drill a pilot hole hole here, then use a 3.5" METAL hole cutter (usually has some kind of non-binding coat, like white paint) to cut the hole. Have fun!
