Installing FMIC
rco8786
I signed up for these boards just to answer this thread.. :)
A system will run off your alternator, not your battery, unless your car is turned off. So just turn your car on when you want to listen to music.
Cyberkreig
Car: 1993 Nissan 240SX SR
well then, welcome to nico.
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
Duh! Cool. <-- my most intelligentest post ever!
unfrgivn
rco8786 wrote:I signed up for these boards just to answer this thread.. :)
Not on first start. The battery immediately sends power to your amps when turning the key from "off" to "ignition" before it even sends power to the starter. If you are running Amplifiers that draw a lot of current and your battery does not have enough current to make the starter turn, then your car won't start, especially in the winter because slimline batteries do not have nearly as many cold cranking amps.
Science Experiment: Grab a multimeter and test the current going to the starter with your system unplugged and then with it all hooked up. You will see a difference.
