Installed the 350z HR Y Pipe
Jacko3
Tampa:
My second gear can actually get close to 65 miles per hour if I push it to 7,000 RPM with test pipes. The 60 mile/hour numbers in second gear is for between 6200 RPM and 6500RPM with test pipes.
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
That is strange I thought a gear output is set at the final drive ratio. anyone care to explain ?
DJ
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Tampa G35 Sedan 6MT wrote:That is strange I thought a gear output is set at the final drive ratio. anyone care to explain ?
DJ
I can't see how what Jacko and Tollbooth are saying is possible. There is a defined gear ratio between the wheels and the engine for each given geat.
Power and Torque increase should ONLY affect acceleration and top speed. There shouldn't be any effect on the gear ratio. This should hold especially true for the 6mt where there is no slip.
It's possible to "fling" the car past redline for a given gear. Meaning, if the Jerk is high enough, it might allow acceleration to continue past when the transmission shifts, but if the vehicle before and after the power mod was revved to redline and allowed to maintain a constant speed at redline, then the maximum speed for the given gear should not change.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
If power increases only affect acceleration and top speed...wouldn't that increase the TOP SPEED in EACH gear?
added power should create higher speeds in every gear if it changes top speed in ANY gear??
am i missing something??
acceleration is obviously increased in proportion to the increase in power...i guess the question is just whether or not that changes speed.
