Kolk1 »
https://forums.nicoclub.com/kolk1-u53942.html
Fri Jun 01, 2007 4:44 pm
Its 7.6 Cu before the port, and its for 4 -12s. Minus the 2 vents, bracing, and 4 subs, its only about 1.5 Cub per sub.
Also, what im mostly proud of, The seats still work perfectly, and the box is only about 1 inch taller than the seats, roughly 2 inchs shorter than the head rest, so it doest block any of my rear glass at basically.
I would have to guess the box weighs about 50lbs. Then 4 subs, SLR battery, 3 amps, im sure it all weighs quite a lot.
We didnt have a demo car for my location(ShowOff Audio) and since im now install manager, I decided to step up to the plate and make my car the demo car.
There is still a lot to do, the box is getting basic face plates so it looks molded to the walls, finish wiring, Door components need replaced with some Memphis M Class components, and then replace the deck with a Kenwook 8019 as soon as it shows up. And that should cover it......... for now.
