biosehnsucht wrote:idle isntability either means you have the wrong MAF or some kind of vacuum leak probably
if you knew what MAF your ECU wanted, you could either get that or use a SAFC to compensate, but otherwise its a big guessing game.
don't recall which way to turn it, just try both ways.. I think "unscrewing" it makes it go higher..
as for codes, RTFSM. There's a whole section on troubleshooting ECU codes in their in the EF&EC section..
slownslurious wrote:I think you should find a stock ecu and start from there, you have no idea what that ECU was tuned for. It could have the rev limiter set at 6k... it could be tuned for RB20, 25, Z32, or Q45 mafs... could be tuned for 370, 440's, or 550's...you are just blindly stabbing in the dark by hooking up parts trying to satisfy this mystery ECU...
also for the record jdm fuel is not rocket fuel or aything, its just measured differently.
AHHHHHHHHHHJDMSIL80 wrote:I have a stock ECU and have tried running with it before I put on the N60 MAF. The car didn't run right with a lot of mis-firing, mostly because I already had the 444cc injectors.
I highly doubt the stock ECU would do me any good at this point, unless if I chip it with another program.
The Blitz ecu doesn't have rev limiter, according to RHDJapan who sold me the ecu, it has boost & rev limiter removed.
The fuel cut-off I was experiencing is mostly associated with the stock MAF, it wouldn't let me boost over 7psi. That is the reason I went for a bigger MAF.
Now its just the question on how to make all the parts work well together. I know a standalone would take care of all these issues, but I really dont want to spend so much money until I get the car running properly...at least.
Not_a_sr wrote:
AHHHHHHHHHH
just put back in your stock injectors,stock maf, and Stock ECU.
buy a ECU or chip that is programmed for the rb20maf, and 444CC injectors (where did you get 444's any how???? sure thats the correct size???)
once you do this your problems will probably go away!!
you are goin to kill your motor with your setup, for the people who think you cant kill a motor by being too rich your sadly mistaken.. it will eat a motor alive, fuel thins out the oil and lowers oil pressures dangerously low. it also induces a condition call bore wash, which eats rings and cylinder walls like its breakfast...
get this thing back to stock and buy a ECU program that works and go from there, or send it to a shop to let people who know what they are doing deal with it... you will not get this thing running right as it is...
and RHDandy probably couldnt tell you the differance between a Sr ecu and a ca18 ecu if it wasnt written on the case, so i highly doubt he has anyclue what your ECU was programmed for.
lolaint that the truthNot_a_sr wrote:and RHDandy probably couldnt tell you the differance between a Sr ecu and a ca18 ecu if it wasnt written on the case, so i highly doubt he has anyclue what your ECU was programmed for.
A MAF/injector/ECU swap is a wise step; if it is too tiresome, reconsider your plans to keep tinkering on your own. It would be in your best interest to heed the advice others have given and get the car running correctly before switching to a PFC.JDMSIL80 wrote:Instead of going back again taking everything apart, Im starting to feel tired about all these problems with the car...Maybe I should go for standalone and call it a day.
Im just one click away from buying the Power FC, does it have the capability to take readings from my N60 MAF and tune from there??
Would it cure all the problems as far as you can see?
http://www2.osk.3web.ne.jp/~t1....htmlbiosehnsucht wrote: However again I'm not sure if anyone has the MAF table for a N60
biosehnsucht wrote:Yes, I'm just pointing out *I* don't know what a N60 is. It's not a Z32, from wht others have already said.
Modified by JDMSIL80 at 9:26 AM 10/5/2005slownslurious wrote:I have a stock mafs and I've had my car up to 15 psi and its just fine... if your mafs is cutting out at 7 psi on a stock turbo ca18 then something isn't right to start with. Personally I would probably get some stock stuff (available cheap from members on this board) and make sure the engine was ok stock. thats always gotta be step #1. If you try to change everything from the start then when something goes wrong you don't know what it is.
Ah, same part# as my RB20DET MAF.. at least he part # part, mine then says J60 instead of N60, interesting..JDMSIL80 wrote:This is the code on the N60 MAF: 22680 02U00 A36-000 N60
well good luck with the PFC tuning, glad to hear you intend to take it to a shop to get it tuned / learn how to tune it.
