So I hooked up the N60 MAF (RB20/VG30) on the car yesterday, the car ran much smoother in the mid to high range and pulls harder with the same amount of boost. I thought the car is finally running great...................
However, now my car cannot hold idle!! It gets really rough fluctuating between 300-700 and gradually dies and stall!!!
I have to keep the throttle over 1300 in order to keep the motor from stalling. The car is barely streeteable because it may stall in the next light or stop sign. But once it gets going, its smooth and power is much better than stock MAF.
Im thinking if bringing the idle higher would solve the problem, but where is the idle control screw??
What is the appropriate modification I should do next? S-AFC maybe?
biosehnsucht wrote:N60 might be VG30 Maxima? not sure..there should be a part# on it, I could tell you what it's from.. in the form of XXXXX-XXXXX, not that it will really help fixing the car..
if it is in fact tuned for Z32 MAF and 444's or 440's or 450's whatever, getting that combo of parts would work.
Also, the ECU does have a limited ability to learn fuel trim compensation values in a limited area of the fuel map (basically the idle / part throttle cruise area), and resetting it would help it relearn faster those areas, but it can only learn to a certain extent..
of course we can't know what it's tuned for.. so this is all a guessing game as to whether it will magically work with a Z32 MAF. It might even be meant for 440ish range injectors and stock MAF, which would explain why it kind of works now after forcing it to unlearn the corrections it was using before..
getting a rom tuned for what you have is likely the best bet, and safest..
If I had a bunch of spare chips on hand I could burn you a copy of my rom, and mail it to you, which is set for DSM injectors (slightly bigger than yours so might run slightly leaner) and stock MAF.. but I have no spares as it is
That is of course if the rom in the blitz ECU is socketed..
Modified by JDMSIL80 at 11:43 AM 10/4/2005
