I feel obligated to jump in here...
adidas2go wrote:Alright guys heres my thing.
I just sold my Injen to Joe. After driving with the stock intake system again, It is DEFINITALY faster with the stock system over the Injen. There is a straight road by my house that I run whenever I get a new upgrade to see If I have a change in performance. I run from the end of the road to a gravel driveway at the other. With no human errors involved, in D, I get to 100mph from this point A to point B with the Injen. However, with the stock system I get to 115 in the same scenario. My point is based directly on the cold air being sucked into the system. The stock system brings in cold air from the grill and routes it through sealed piping to the throttle body. Nowhere for hot air to begin to come in. However, with the Injen its sucked straight hot air off the transmission. I mean honestly, the transmission is producing massive amounts of heat during acceleration. So it stands to reason that the stock system would be faster.
Blake, I understand your testing procedures however there is a lot to consider...What were the weather conditions on these days? Was it the same temperature? What was the street condition like? clean one day possibly dirty the next? Did you have any differences in weight?
The reason I ask is because 15 miles per hour is a MAJOR difference in speed. Consider that difference in a 1/4 mile comparison...15 MPH is HUUUUUUGE. In my opinion I don't think an intake could be responsible for 15 MPH.
adidas2go wrote:As for the Dyno numbers. Companies get Dyno numbers from closed enviornments. They cool a dyno room down to about 45 degree and also run dynos that read high. They can doctor dyno numbers any way they want to.
You've seen our dyno...It sits outside on the hot asphalt...Yes, we have fans in front of the car but they run allll the time no matter what we're testing. Whether it's our parts or factory parts. Despite whatever conspiracy theory thoughts you might have...They don't exist.
adidas2go wrote:In retrospect guys, Its really about what your looking for. I liked the Injen personally, faster or not, If I wasn't getting a turbo, I would have kept it. Its a nice bolt on and has many positive qualities over the stock system. Im sorry if anyone took it the wrong way when I stated this information earlier, this is just what I believe based on driving the car with and without the system myself. Maybe someone out there only has and Injen intake on their 3.5 and can belly up against a stock 3.5. See who wins
At the end of the day an aftermarket air intake is doing quite a bit more than just pulling cold air.
You also need to consider airflow. Air, does not like to travel over the accordion tubes that car manufacturers put in to the intake tracts. They do this for ease of installation, less vibration/drone, allowance for complete engine movement during normal operation. However, they do not do it for improved airflow.
Also, with an aftermarket air intake system you get a larger, more efficient air filter element. Our testing has shown that the K&N filters are superior to any other filter element on the market but Injen and others definitely offer a great product.
In reality, an properly developed air intake does make power. Will it offer as big of a gain as say an exhaust? no...It won't...There is not as much restriction to remove. However, it will make power. It will provide you with a superior filter. It will offer a great sound. It will offer a great look.
There are definitely some companies out there who don't care about the power gains and just make stuff up. But, to generalize and say that all automotive tuners doctor dyno numbers or set up special test scenarios is a pretty ridiculous statement to make.
My recommendation...Go with a company you know and trust. If it sounds too good to be true...It probably is. You won't get an increase of 10 MPG with an intake. You won't drop 2 seconds in the 1/4 mile. You won't gain 30 horsepower. However, you will gain some power, you will feel the gain, you will have a more efficient air filter and you will have a great sound. Also, you have a great showpiece for every time you pop the hood.
