Carl H wrote:i have been having similar issues with my vh as it would run great from a dead cold start but then once you shut it down it would drop a cylinder or 2 and then gradually come back.now it has at least one dead cylinder and i suspect the injectors are starting to fail.
I would defiantly follow the above instructions on testing them.---------------------------------------------------------------------------------------------------But I would like to add that when i pulled off the engine ornamental covers (The black pieces, on says the HP and Torque that the car produces), I found that I had purple injectors. And since they were defiantly the phase one injectors that leads me to believe that I have the old BWD (China) injectors.
So that said I can say with 50% certainty that the old ones are crap, But on the new injectors (That 1990Q45 is trying out) I hope they work as expected (Being able to handle E10).
And as for the TPS sensor being perfect well since I took longer than expected to replace it, the coolant had cooled down below 179* and I had tuned it to lower than hat it should be (.44 volts) and it is currently set to (.36 volts) so I need to fix it tomorrow (screw) because today when i let off the gas it would incorrectly try to down shift into second gear.
So from my experice on the TPS sensor: If set higher than .44 volts car will shift harder (AT-CHECK will not work and possibly stay at the AT-CHECK screen). If set lower than .44 volts the car will incorrectly down shift (AT-CHECK will work but you won't know whats wrong, therefor making it harder to diagnose to those who don't know much about the car).
The TPS has to be set exactly at .44 volts. (AT-CHECK will work correctly and no need to worry about the TPS sensor).
