ppastos wrote:OK sorry to bring up and old topic, But to add to this the car kicks down when its at 25 MPH but above that it fails to kick down? above that it doesn't feel like its going to a lower gear I also look at the RPM's and see no increase.
Trans should downshift at any speed except when already in 1st (or if above max RPM for 3rd gear) if the pedal is floored. In other words, it should, depending on which gear you are in and what speed you're going, downshift into 1st, 2nd, or 3rd. Under some conditions, sometimes it might even downshift TWO gears. You can't miss knowing if the trans downshifts by the jolt, noise increase, and almost instant RPM increase. If this doesn't happen, say at 60 MPH for example, you are right in trying to diagnose why it won't downshift. Keep digging, you'll find it. Until you find and fix the problem, you can always manually downshift to pass someone. Easier to just kickdown though, so I'd perservere and get it taken care of. Looks like qsiguy has you on the right track. I suspect he can help you fix it.
Good luck.
