injectors
bklyns hiway bandit
Car: nissan 240sx hatch
does anybody know if 350z injector would fit or work on a SR20DET.
Jdubsx
Car: '93 240sx coupe, 92 Caprice Wagon, 93 Acura Integra
I think that VG30s use top feed injectors while SRs and KAs use side feed. So 350Z injectors would not work unless you changed your fuel rail to a kind that will take top feed injectors, and then there would been many other options for injectors.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Jdubsx wrote:I think that VG30s use top feed injectors while SRs and KAs use side feed. So 350Z injectors would not work unless you changed your fuel rail to a kind that will take top feed injectors, and then there would been many other options for injectors.
The VG30 is the motor found in older maximas and NA 300ZXs, it uses the same 370cc injectors that the SR20DET uses, the VQ35 on the other hand is found in the 350Z and many of Nissans other vehicles, Im not sure what kind of injectors it has
S13FASTBACKSR
Car: '92 Fastback SR powered
stock 350z injector size is 380cc. May i ask why you want to put those in your sr? Not an upgrade right? because the stock sr size is 370 so that is hardly hardly an upgrade..pointless if it were for an upgrade..plus they wont fit without some good modification. If you need a replacement because yours are bad then you can get them from a 90-96 300zx TT model direct drop in and go
Jdubsx
Sorry. I meant VQ35. My bad.
bklyns hiway bandit
my boy had gave me them for free, so i wanted to make them usefull lol.
zanilth
Car: 1995 Nissan 240 SX
bklyns hiway bandit wrote:my boy had gave me them for free, so i wanted to make them usefull lol.
Go sell them to some idiot with a honda, tell them it will put him at 600 whp.
S13FASTBACKSR
lol
IanS
zanilth wrote:Go sell them to some idiot with a honda, tell them it will put him at 600 whp.
cmon 380cc injectors are only capable of making 380 hp at most, unless they are yellow, then they are good up to at least 450 , its too hard to play tricks on honda guys, they know everything
