injector wont fire
LordOfTheMiasma
Car: s-13 hicas sr20det 240sx
my number 4 injector wont fire at all. car runs fine.. just only on 3 cylinders. there is power coming out of the ecu from the blue and black wire. when i check the wire on the plug that goes into the injector there is half the power of the other 3.... i have no idea. the wire isnt broken anywhere. any ideas would help greatly.. please help me....
LordOfTheMiasma
cmon someone needs to help me paleeeeese... or there will be one less 240 on the road when i set it on fire...
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
is there an injector pulse at the ecu, No = bad ecu
Yes,
is there injector pulse at the injector, No = wiring problem
Yes,
is there ground at the injector , No = bad ground
Yes,
if you have all three, then you have a bad injector
LordOfTheMiasma
i swapped the injector with 4 other ones.. one at a time.. where would the ground be bad?? the injector has a pulse and it seems like the ground is bad.. where the hell is the ground for it?? there is the red wire.. which is the positive.. and the blue and black that is the ground correct?? both go nowhere but to the ecu correct?? there is pulse coming out of the ecu on both wires but half at the injector... where would i check the ground??
