Injector resistence
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
Do I need to a resistor on 370cc injectors from a CA18t when I install them on my KA24 E?
wild_maxx
Car: 90 TT pearl yellow z32
i believe they are high impedence but you can easly check with a multimeter. i just used some 88 mazda rx-7 460cc high impedence injectors. they fit nice and tight in the fuel rail.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
what is considered "high" impedence and what is "low" if I check them, and what are stockers.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
High is ~11 (or so) ohms...stockers should be 11-12 ohms.
- Brian
hannibal
Car: Red Line to Glenmont
CA injectors are low impedence.CA18DET and RB26 = low
KA-E, KA-DE, RB20/25, SR20, VG30DETT are all high impedence...
Toahk
Car: 97 ....
IWannaS15 wrote:CA injectors are low impedence.CA18DET and RB26 = low
uhh wrong. I dont know about the others, but ka-de, sr20 etc are all low.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
I will check both my CA18det and KA e injectors tonight
hannibal
Thats the info I came up with from searching the net.
I wouldnt bet my life on its accuracy, but I wouldnt post unless its something I believe to be true. Check your sources. The only low impedence injectors Ive heard of are the CA and RB26 top feeds...
240SicknessX
Car: 96 240 SE
i also know that the z32 370s fit the ka24de, so they must be low impeadance also
*edit* - i checked the fsm, 96 ka24de injectors are suppost to have 10-14 ohms of resistance. They are not low impeadance.
Modified by 240SicknessX at 9:48 AM 3/29/2005
wild_maxx
buy these and send them in to get cleaned and flow tested.
http://cgi.ebay.com/ebaymotors...33554
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
Okay I checked the injectors.
Stock KA24E 2.7 ohms
CA18DET 14.1 OHMS
So my next question is do I just need to put a resistor, diode, anything in line?
Thanks
I must have been sniffing the gas
Stock KA24E 14.1 ohms
CA18DET 2.7 ohms
Modified by LEMHEAD16 at 7:16 PM 3/28/2005
wild_maxx
i think thats wrong. the stock kae injectors are high impedence. correct me if i am wrong but i have never heard of low inpedence kae injectors.
:: orion ::
IGNORE ALL THE "I THINK" COMMENTS AT THE TOP OF THE THREAD.
KA 270cc injectors are HIGH IMPEDENCE.
SR 370cc injectors are HIGH IMPEDENCE.
"Lem" - remeasure your KA-E injectors...they should be high impedence.
- Brian
wild_maxx
I THINK I THINK I THINK I THINK I THINK I THINK I THINK I THINK
HOWS THAT?
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
LEMHEAD16 wrote:Okay I checked the injectors.
CA18DET 14.1 OHMS
Thanks
CA18DET 2.7 ohms
14.1 is high right and 2.7 is low
Should I just put a 11 ohm resistor in line with the power or with the ground?
hannibal
Thanks Orion. Next time I'll write it in caps...
Toahk
Car: 97 ....
:: orion :: wrote:IGNORE ALL THE "I THINK" COMMENTS AT THE TOP OF THE THREAD.
- Brian
SR high impedance? I think not.
hannibal
Just read today that GTiR SR20's use top feed low impedence injectors. I think theyre 440cc...
Lem, I really dont know how to wire in the resistors. I assume they would go on the 12v side.
240SicknessX
Car: 96 240 SE
:: orion :: wrote:KA 270cc injectors are HIGH IMPEDENCE.
- Brian
1996 240sx ka24de, injector resistance per FSM page EC-298, is suppost to be 10-14 ohms at 77 degrees farenheight. This puts the de injectors in the high impeadance bracket
low impeadance injectors measure 1.7-3.0 ohms, high injectors measure 10-16 ohms.
:: orion ::
Toahk wrote:SR high impedance? I think not.
Please get your facts straight before posting that as fact...I'm not tryig to be an A55, just trying to keep the info reliable and correct.
It's common knowledge that you can drop SR injectors into a KA rail and use an S-AFC to tune...no resistors needed.
If they were low impedence and you used them on a stock ECU with an AFC...it would kill the injector drivers and the car would not run. That does not happen.
As I posted above...they ARE both high impedence, I'm 100% sure...I'd bet my life on it.
- Brian
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
My original question had nothing to do with SR or DE injectors. Here are the facts.
Ca18det injectors 2.7 ohmsKA24E injectors 14.1 ohms
Does anyone know how I would wire the resistors and what resistance to use?
Thanks- Josh
:: orion ::
Yeah, sorry that got off topic a little...
Anyway, a common solution is to pull a resistor block off old Preludes (IIRC)...search the web for it, you'll find how-to's and such.
- Brian
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
thanks brian
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
Here is what a search came up withhttp://www.acceleronics.com/versafueler.htm
For 395 dollrs I could get a new set of bigger high Z injectors. Iguess I should have researched this before buying injectors, but I swear I read a post about CA injectors working on the E.
WDRacing
Thanks for the corrections Bri.
I posted my injector spread sheet and its now a sticky. In case anymore situations arrise like this one.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
that is a great sheet WD
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
anyone?
preston240sx
Car: Nissan 240SX S13
Here's my list of Injectors:Top Feed Engine Style Size Impedance* Years / ModelsNissan KA24E Top feed 260cc High S13Nissan CA18DET Top feed 370cc Low S13Nissan RB20DET Top feed 270cc High R32Nissan RB26DETT Top feed 440cc Low R32/R33/R34
Mazda FC NA Top feed 460cc Low 86-87Mazda FC NA Top feed 460cc High 88Mazda FC NA Top feed 460cc High 89-91Mazda FC turbo Top feed 550cc Low 86-87Mazda FC turbo Top feed 550cc High 88Mazda FC turbo Top feed 550cc High 89-91Mazda FC NA Top feed 680cc Low 84-85
DSM 3000GT/Stealth turbo Top feed 360cc Low 91+DSM Talon/Eclipse nonturbo Top feed 390cc Low 89-94DSM Talon/Eclipse 1G Top feed 450cc Low 89-94DSM Talon/Eclipse 2G Top feed 450cc Low 95-99Mitsubishi Evo Top feed 510cc Low Evo 1-Evo 3Mitsubishi Evo Top feed 560cc Low Evo 4+
Subaru WRX Top feed 420cc 02+Subaru JDM STi Top feed 550cc (565cc?) 99+??
Toyota 3S-GE Top feed 295cc High Toyota 7M-GE Top feed 295cc High Cressida, Supra mk3 NAToyota 2JZ-GE Top feed 315cc High Supra mk4 NA, SC/GS/IS300Toyota 3S-GE Top feed 315cc High Toyota 7M-GE Top feed 315cc High Cressida, Supra mk3 NA
Side Feed Engine Style Size Impedance* Years / ModelsNissan KA24DE Side feed 260cc High S13/S14Nissan SR20DET Side feed 370cc High S13/S14Nissan SR20DET Side feed 480cc High S15Nissan RB25DET Side feed 370cc High R33/R34Nissan VG30DETT Side feed 370cc High Z32
Mazda FD Side feed 550cc High 93-98Mazda FD Side feed 850cc High 93-98Mazda 20B Side feed 550cc High JDM Mazda Cosmo?
Subaru JDM STi Side feed 550cc (565cc?) High pre 99Subaru STi Side feed 565cc High 03+
Toyota 7M-GTE Side feed 430cc (440cc?) Low Supra mk3 turboToyota 2JZ-GTE Side feed 550cc Low Supra mk4 turboToyota 3S-GTE Side feed 430cc (440cc?) Low MR2, 91+Toyota 4A-GZE Side feed? 365cc Low MR2, MK1Toyota Celica GTS Side feed? 310cc High 2000+Toyota JDM 1JZ-GTE Side feed 430cc Low Chaser, Supra mk3?Toyota JDM 2JZ-GTE Side feed 430cc High?* Supra mk4 turboToyota JDM 7M-GTE Side feed 430cc Low Supra mk3 turbo
Ford Turbo Coupe ?? 30lb (~315cc) Low 86-89Ford Turbo Coupe ?? 35lb (~365cc) Low ??Honda Prelude (H22A) ?? 345cc Low 92-96 VTEC
*ImpedenceSaturated = High ImpedencePeak and Hold = Low Impedence
use the chart....jeesh
preston240sx
oh yeah thats WD's chart
santi
Car: s13 ka-t hatch
:: orion :: wrote:It's common knowledge that you can drop SR injectors into a KA rail and use an S-AFC to tune...no resistors needed.
- Brian
THANK YOU BRIAN!! thats the only piece of info i was lookin for in this thread
