kapower06 wrote:Nissan KA24E Top feed 260cc High S13Nissan CA18DET Top feed 370cc Low S13
Now that we know that ca's are low and ka-e's are high what, if anything, needs to be done to use the ca injectors with a ka-e...Orion said to use an injector resistor from a prelude? Someone on these forums has to have had a ka-e with ca 370's at one time or another. Thanks
Well, I'd hate to bring in more confusion, but I dealt w/ this issue a few months ago too. This was discussed last year.
CA18DET are HIGH IMPEDANCE. They are listed as LOW because they are attached to a resistor - the injectors themselves should be high impedance. I think this is the source of the confusion.
So... IWannaS15, I hope you are able to accomodate for HIGH/LOW injectors in your chart w/ a list of which ones have resistors (that would probably be very hard, but may an *astericks or something).
So, if you have ca18det injectors, they should in fact be high impedance and will drop right in.
The CA18DE (non turbo), I believe may be low - not sure about that one.
Only reason I know this is because I have a set of ca18det's I bought and was scrounging for info back in October 2004.
Don't take it from me:[quote=""Toahk""]Ok just found out, stock ca18det injectors are 370cc low impedance, top feed. Stock Ka24E injectors are 270cc high impedance, top feed.
Edit, 370's are actually high impedance with a resistor to make them low impedance. Just remove the resistors and jumper the wire where it was. [/quote]Original Thread:
zerothread?id=82238
Edit: So.... LemHead16, check to see if you are measuring your injector w/ the resistor wiring still intact.
another edit - to quote myself cuz I'm a ho:
brokeAs240sx wrote:I believe he is saying you only need resistors when you are trying to go to low impedance resistors.
The CA injectors are high impedance if you don't use the wire (which contains the resistor to make it low impedance).
So basically, I believe it is just plug and play.
KA24E - high impedanceCA18 - high impedance w/o the wiring
