float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Jan 07, 2010 6:19 pm
No. The cams line up with the marks on the backing plate. TDC is TDC as far as the bottom end is concerned.
Which MAFS are you using?
Have you pulled the codes from the ECU?
Get a noid light and see if the injectors are firing.
If the injectors are firing, check the coils and make sure you have spark.
If the injectors aren't firing, you either have a bad CAS, bad resistor pack, bad wiring, or a bad ECU.
