I just got finished with a month of having to look at the CEL on the 90Q because of code 45. All the injectors were ohming good and the gas mileage hadn't dropped so I knew the injectors were probably OK. I did add 2 bottles of Redline injector cleaner since I hadn't done it since buying the Q 5 months ago but the CEL didn't go away.mike7401 wrote:.....I can't seem to get a right reading on ks, mass sensor cleaned, connector seems ok, no change when moved.......
See if this helps to ohm your KS and fuel injectors.mike7401 wrote:I can't seem to get a right reading on ks....
On the 95Q you may have to turn the ignition to the ON position to get a reading. If you clear the codes does the KS code come back right away?mike7401 wrote:I can't get a right reading, will get my other tester. The Q feels so much better.
If both KS were dead it would affect your acceleration. If only one is dead you won't notice it. If for some reason you can't get a reading from the KS harness clear the ECU codes and if the KS code doesn't come back immediately they're fine.mike7401 wrote:......I wonder if I should even change it, if it shows bad. Will the pickup be alot better and mileage, when changed.
Time to measure fuel pressure.Paul Wall wrote:My bet is the fuel pump and soon enough if not already a bad Fuel Pump Controller.
Did you replace the fuel pump after it had been buzzing for many months? It may have taken out the FPCU. An easy check is to bypass the FPCU and run the fuel pump on high speed only. Remove the trim piece between the trunk and the fuel tank and unplug the FPCU. It's in the background in the pic near the PR speaker. On its connector run a jumper from the pin shown to ground. If the car runs good it's a bad FPCU.mike7401 wrote:No check engine light no more, but stumble is worst now. Especialy sometime at idle in neutral car turns off. In drive at idle engine want to turn sometimes but not as much. Then sometimes its great. Car does seems to pull stronger, but sometimes at around 4k rpm, doesn't like to rev past 4k rpm. Code for 34 (ks) comes back right away, afer reset, only code. Mileage is 120 k......
