msudawgs98 »
https://forums.nicoclub.com/msudawgs98-u12622.html
Thu Feb 26, 2004 4:42 am
"Pull the fuel pump fuse, and crank it over several times...hopefully it'll start after a bit. I think you're running way too rich. Maybe there's an injector leak? What year is the car and how many miles? A bad O2 sensor would make things worse too. DId you notice how the exhaust looked when it ran? I think the pump is in the tank...most of us are Q owners, but the J is mechanically very similar. Do you have a fuel pressure gauge?"
I have a 1994 J30t with 140000 miles. I cranked up up the J30 numerous times until it finally quit due to a dead battery. What I noticed is that the car has started, instead of half a second, for a couple of second and it just dies. As far as the injector leak, how would I check it? As far as a bad O2 sensor, where would it be located. I failed to mention that the check engine light has been on and off from time to time. What are some of the problems with a check engine light? Would a bad O2 sensor make the check engine light come on? As far as the fuel pressure gauge in the J, mine doesn't come with one. Thanks again
