lol your not a motor mech then the amount of parts i have installed that where new out of the box and ether didnt work or failed shortly after install is to many to list in that list are thermostat's, spark plugs, ball joints, oil filters, water pumps and lots morekatillidie wrote:Yes i know how to test it.. Its brand new oem... I highly doubt its faulty
Good Deal. I've been reading along, and was wondering how to get that Stuck Stud out. They may have used some Red Locktite, or it may be rusted in place. I was taking the control's off of a Motorbike HandleBar once,, and they had Red Locktite on the center bolt holding the hand hold's. It's a miracle,, I got those bolt out.I drilled a new hole in the intake manifold and taped threads to put a new bleeder screw in tonight. tomorrow im goin to vacuum bleed it again and try to burp the system...
Sound's to me, like you are the one that doesn't know.Adverse Effects wrote:lol your not a motor mech then the amount of parts i have installed that where new out of the box and ether didnt work or failed shortly after install is to many to list in that list are thermostat's, spark plugs, ball joints, oil filters, water pumps and lots morekatillidie wrote:Yes i know how to test it.. Its brand new oem... I highly doubt its faulty
but your the one here asking for help
hope you have some luck
bye
true i have not worked on that particular motor but i have been in the trade for 25+ years tho (not including apprenticeship and 4 years with a Formula Vee team)BRubble wrote:Sound's to me, like you are the one that doesn't know.
yes i read that and your point is?On that Engine,, there is a Air Bleed Screw,, that was broken off,, and then the Easy Out Broke off as well.
look at what you just did and you didnt help at all and you attacked someone as wellThe Remark's that you took the time to expell were not needed at all.
at lest i took the time to fill out my profile instead of just doing as little as possible to get in to a forum and act like a troll like some peopleThe Avatar that you have,, explains your Attitude as well.
All that may be True as Well, However Adviseing Someone to Drive to the Nearest Hill and Burp the Air Out of The Cooling System Could well have done Damage to His Engine.Adverse Effects wrote:BRubble wrote:Sound's to me, like you are the one that doesn't know.All that may be True,, but in this Case, No Advice from you would have been better.true i have not worked on that particular motor but i have been in the trade for 25+ years tho (not including apprenticeship and 4 years with a Formula Vee team)
On that Engine,, there is a Air Bleed Screw,, that was broken off,, and then the Easy Out Broke off as well.I had the KA24E Version of that Engine,, and the Air Bleed Screw, Functioned as described in the Service Manual. Seemed to me that You were trying to get him to modify his Thermostat.yes i read that and your point is?
i have worked on lots of cars / trucks that have bleeders on the cooling system and a lot of them are non functional for one reason or another and the process i have described is one of the best ways to get around the problem.
No Advice is Better than Bad Advice.i didnt see you helping
