In search of 340mm x 32mm rotors, please help.
working4aS13
Car: Base 95 240SX
I'm in search of 340mm x 32mm rotors for a Nissan five lug application. Does anyone on this forum know where to purchase such a rotor? Any additional information would help my quest.
The reason: I have BNR32 GT-R calipers (296mm rotor diameter) and caliper bracket entensions (Those that you commonly see on eBay that are intended for using Z32 calipers and Z33 track rotors on a S13/S14/Z32.). The caliper bracket moves the caliper 44mm away from the hub. 296 plus 44 equals 340. Or if you'd like 296 (GT-R rotor size) minus 280 (Z32 rotor size) equals 16 plus 324 (Z33 rotor size) equals 340. I'm positive 340mm is the size I'm looking for.
Information was referenced off of my own messurements and the Ultimate Rotor Guide located at zerothread?id=111021
hannibal
Car: Red Line to Glenmont
I'm going out on a limb here and saying those will be hard, if not impossible, to find. Brembo doesnt list any 340mm rotors and they make a crapload of rotors for different brands.
http://www.brembo.com/Catalogo...Guest
Those GTR32 brakes arent strong enough for ya???
nismofly
Car: 89 Nissan 240SX Hatch
i honestly couldnt tell you if you need 340mm rotors or not...but if you do good luck because ive never seen them
youll find 328, 332, and 355 everywhere...but never 340
180fan
Car: 89 fastback
try racingbrake.com and look for the c6 vette z51 "enthusiast" package. It should be a 2 piece design but may have released a 1 piece, but bototm line, it matches your 340mmx32mm requirements.
