In need of specs for swap to a 79 camaro
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
wayner
Car: 1990 nissan 240/redtop SR
yes yes i said it into a 1979 chevy camaro now some qusetions i need answered are as follow....
1. im planing to make it all wheel drive by getting a front clip now i cant really find out if the skyline has a defined frame (uni-body or full) im would think of it being a full frame but i could be wrong...
2. also what skylines were all wheel cause i have read some can be rear only by chance and i would like to know for sure
but hear me out i picked this car up for 400 bucks and its solid with a 6 cyl in it and a 350 small block is just over played so i though to change things up by going all wheel and placeing a RB in it.
any in put would be great.
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
you have watched tooooo much fnf
wayner
no not really i didnt even like the movies all that much i just want to do something else then just putting an all too common 350 in it and if it can be done swaping the all wheel drive as well it would make it one of a kind with go.
snwbrdr435
well in that case its guna cost quite a bit and there is going to be tons of custom fab parts
wayner
well not nessarly yes there will be tweeks here and there but what i need to know is the frameing of the skyline, wheel bases, and so forth cause i im thinking fo just using the skyline frame to keep the fabing down.
whoflungpoo
Car: 2006 Infinity G35 Sedan
2003 Evolution VIII
I hate to be the d!ck, but if you have to ask these questions, you probably don't have any business swapping in an RB, nevermind trying to convert it to AWD.
I will go out on a limb here and say that EVERYTHING will have to be fabbed. ALL of it.
wayner
well i do have to say thanks for the vote of help thats great
but im looking to see from somebody who knows the skyline to help me out with my theroy of useing a front clip under the camaro if that would be possible instead of trying to make the awd under the camaro body. thats why i need specs of the skline to see how the numbers match.
but you know thanks anywas "d!ck"
themadscientist
My advice to you is walk away. It is something that would take a ton of work and at best be nothing more than a curiosity. I would suggest you instead look at grafting a camaro shell to a modified syclone frame.
turbo corey
to do a awd comaro with a rb26 is cool but you can take the motor and put it in the camaro with some mounts makeing it rwd.to make it awd is not ez .go rwd .gtr is awd gtt is rwd. good luck
MrAlien
to make it AWD you will need the skyline GTR's entire drive train and suspension. and unless you wanted the car to fall apart you would need a custom frame.
you could buy several GTRs for what this would cost you to build.
wayner
thats what i planned to do useing the skiline frame and streching to to fit under the camaro that way i wouldnt have to fab the awd to the camaro frame that i know would never work thats why i wonder if the skyline has a full frame under it cause that would make things much easier but if it is a uni body i would have to make a frame and convert the rear end supenison of the camaro to the skyline.
themadscientist
the Skyline has no frame, it's a unibody. You are proposing a very serious project with very little return on the investment.
MrAlien
why not just buy a skyline GTR?
themadscientist
That is an obvious question. It has no place here!
StricNyne
ask full race they prolly charge u 10k hahaha
martJOB
Car: 1964 elcamino
you're better off starting with an astro van AWD base....im being serious when i say that. most of the custom awd muscle cars start off with the astro van base
BOOMSHAKALAKA
wayner wrote:i just want to do something else then just putting an all too common 350
Man that is the gayest idea I've ever heard of. Seriously. Just get a 454 or an LS1 and call it a day.
Not all unique swaps are cool.
MrAlien
502 and a blower
White Comet
Car: fc, s13 and mazda6, Sierra
martJOB
Car: 1964 elcamino
go diesel
White Comet
boo
NISTECH
Although this would be quite a novelty item, like mad said the investment and personal satisfaction wouldnt be there.
I have an 81 camaro in my garage.Same as the 79. The car is also unibody with only a subframe up front. It weighs in at a heafty 5000lbs, the front suspension set up with upper and lower control arms would be imposible to install front diff and axles without complete fabriaction of a new front suspension. I have worked and driven this car several times over the last 20+ years. This car is only really upgradable for straight line performance. The handling in twisties is hideous. Like these guys are saying go with either the common small block configuration of an lt/ls or go for a bigblock and enjoy the car. Unfortunitly being in california I am limited to the pre 95 lt swap to keep it street legal with perfomance options.
Unless you have LOTS of money to blow and just want a novelty item with no real gains stay away from your propsed swap.
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
White Comet wrote:454
martJOB wrote:go diesel
PFFFFFFFT
drop in a K20-A Type R make like 180whp and 102 Tqthen get those huge VTAK cams so after 7k u whp triples to 500
White Comet
S3t0_S13 wrote:
PFFFFFFFT
nah he needs one of the gtr mustangs with the supercharged rotary with cams and pistons
S3t0_S13
Giant Leprechaun
Car: 1990 240SX Hatchback - 1994 Land Rover Discovery
S3t0_S13 wrote:http://www.youtube.com/watch?v=hVlA1eBZ9Cg
found ur guy
There you go Wayner. Slap GTR emblems on your 6 cylinder "muscle car" and call it a day.
BNR32
Car: BNR32
the correct way of doing the AWD swap,and its been done on many late 70`s pre 84 vetts .is by using the GMC Syclone drivetrain
White Comet
found ur guy
yep thats the one. makes me laugh every time
the owl
you car will be faster if you just but a built 572 bick block in it man, get a blower and whatnot and your in a fast *** car
Asmar
Car: 1994 Nissan Skyline
Very nice!
Return to “GTR Forum / Skyline Forum”
