improving the ride for my 1993 240SX
bransonfink
Car: 1993 Nisson 240SX
With the economy not likely to improve very fast, I turned in all my leased vehicles (2)
and broke out the 240SX out of storage. It has been in storage for 4 years although I would drive it for a day once a month just to keep things working. Needs a tune up which I will have done tomorrow, but my question is, how do I make the ride feel a little bit smoother.
I got on the freeway last night and at about 55 mph I could hear a humming noise and slight vibration to the body of the car. It wasnt out of alignment because the steering wheel was not vibrating. But its like you can feel very bump in the road. I know that the 240SX was not made as a cruiser, but this felt like my old Nissan pick-up truck that I had when I was a teenager. It has to be better than that??????????? Any solutions????????
Thanks
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
usually a tight, stiff ride is what most s chassis owners want... im clueless
S14Kouki10
Car: 1997 240sx
you should get coils. :bigthumb:
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Luxury tires, balanced, alignment, and replace those worn out links and bushings.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
How many miles are on this car?
What kind of vehicles were your old daily drivers(the leased cars)?
It could be that you just need a little maintanace, and some tires, or it could be that you are just used to a higher end car.
Generally speaking, a shake in the steering wheel is NOT caused by alignment, that is a common misnomer.
PS, welcome to Nico. You should post some pictures of your car. All that time in storage tells me you have a clean 240 on your hands.
simmode1
Car: Red '95 S14
OutToWinPAHC wrote:Luxury tires, balanced, alignment, and replace those worn out links and bushings.
Precisely. And check your tire pressure too...
motoman399
Car: 98' wrecked (RHD coming soon) 240
you may have warped rotors also, or a bad wheel bearing. if you really want the quite ride and are willing to do a little work, you can put expanding foam in between all the open spaces in your body. like the A/B/C pillars and everywhere else it can fill a gap. also some dynomat would work very good too. i have never done these but have heard amazing things about them. and yes lets see this car!
AZ89two4Tsx
240s are just not comfortable cars, period.
They are light, noisy, and were built as economy cars. By keeping it maintained and up to spec it'll be decent, but never really comfortable. If you're going to start putting money into yours, I'd focus on performance suspension upgrades, not comfort. There's really no "comfort" upgrades out there anyways.
The vibration sounds like you probably have a tire out of balance.
motoman399
hey here are some pics of his car that he emailed me. it seemed from his other posts he couldnt figure out how to post them so here they are.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
How do pics make the ride better?
motoman399
well it doesnt... dont be rude some people wanted to see his car because it had been in storage for so long and they wanted to see how clean it was. so there it is. now dont be an ugly mod!
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
motoman399 wrote:some people wanted to see his car because it had been in storage for so long and they wanted to see how clean it was
Ian said he wanted to see it.
hatedinthemind
Car: S13 Coupe, Subaru Forester
Pretty clean :dblthumb:
Hoffman5982
Car: '95 sr20det 240sx
motoman399 wrote:you may have warped rotors also, or a bad wheel bearing. if you really want the quite ride and are willing to do a little work, you can put expanding foam in between all the open spaces in your body. like the A/B/C pillars and everywhere else it can fill a gap. also some dynomat would work very good too. i have never done these but have heard amazing things about them. and yes lets see this car!
He's right, although I wouldn't use dynamat, its too overpriced. The only reason I used it is because I can get bulk packs for 90 bucks. I also fulled most of the dead space with Great Stuff. It cut down on road noise a little, but more importantly it made the car feel more solid. Another thing to try is to take out the dash and other panels and spend the day tightening everything that has come loose.
