or your egr valve is badSeVa-S13 wrote:My guess is there's a leaking/cracked vacuum hose at the rear of your intake plenum, probly near the EGR valve.
From what you described so far I would also say dist cap. Then again, it could be a million other things.wrightme43 wrote:I rolled my diag dice for you http://creativedice.com/productinfo.html they say you need a dist. cap.
OR you could maybe give more info, make a plan and work thru it. Do you know how to test the EGR? Do you have a vaccum pump?
Or you could take it to a shop and pay for experince.
Im with this guy.wrightme43 wrote:I rolled my diag dice for you http://creativedice.com/productinfo.html they say you need a dist. cap.
No need to remove it. Just remove a hose attached to the intake hose and spray cleaner there.goj_cloud wrote:how od i take out the icv to clean it, also were is it located?
Never mind man I just looked at your other thread. WTF man. Fix the freaking plug on your MAF. Seriously, If your next post doesnt have a picture of a proper correctly wired MAF plug installed on your car I hope no one answers any questions for you again.wrightme43 wrote:Ok man, I know I am wasting my time but here goes. THIS IS ONLY A GUESS!!!!!!!
Its a guess!!!!
quite often the problems you describe are caused by a defective cam or crankshaft position sensor on different vehicles. Do I know that it is the case on your car???? NO!!!!
It could be many things, but I get the feeling you are just going to throw parts at it untill it works. So hey try that one. If I am right I am a genius, and if I am wrong I am some ***hole from the internet.
