j240sxxx »
https://forums.nicoclub.com/j240sxxx-u134902.html
Mon Nov 02, 2009 1:04 pm
So yea I cut my dash today.. I thought I f*cked it up but all is good that Template was off by just a little but you can eye ball it. I took the hud dash out of my coupe and took the hud off and test fitted it a few times. I was off with the cutting but not horrible. Still looks good.
First I taped the template on then marked with a black marker where to cut.Then with a razor I cut very carefully, then pulled the skin of the area off.Then I took a 1 1/2 inch drill bit and made a holeThen I used a hack saw blade (just the blade) and started trimming away.Once I got everything to fit flush I drilled holes for the hud screws.
It wasn't really hard just time consuming. but Thanks 94_240sx.
Now time for the pix.
