There's this trim that goes on top of projector, so any flaw will be covered by it.guitarpro_1st wrote:just word of advice dont cut the whole too big too small is better than too big lol j/k
It took me about an hour to take out the dash and thats with a few coronas when I took breaks, so basicly I was d***ing around. To put it back, shouldnt really take much longer just make sure you connect everything back properly, including the vents, etc. I think there is a write up somewhere on the forum, good luckAZ89two4Tsx wrote:Bumpity bump bump. I am also interested in this even though I don't have a vert.
Btw, for a noob like me, how long do you think a dash swap would take? Idk, I'm not too excited about cutting into my mint dash.
I try to stay away from Dremel because it makes such a mess. I usually run vacuum cleaner right next to it when I cut plastic and put strong magnet when I cut metal. Of course, I do that when I have to cut something on the car.amolao wrote:Because of the proximity of the windshield and if you leave the dash on, the best tools to use are X-acto knife blade for the first two layers and a dremel/small sawblade for the tough plastic. Just a suggestion....
On eBay they go for about $200-300 for the working USDM cluster. Problem is it's not easy to find WORKING unit since most of them are busted.justclay wrote:This may be somewhere else on the forum, but how much does the HUD cost and what vitals does it display?
No. impossible to change color.rsagen wrote:I was wondering if there is a way to change the color of the HUD that goes on the window. I dont no if everybody elses is also green but that is the worst color. I was looking for a blue or red.
Well, you can try to coat the small window on HUD unit with some red vinyl, but it's not going to be as bright as original.rsagen wrote:that sucks. im going to try to figure something out tho....
