lolBlack on Gold wrote:I vote SEARCH
yea ive been looking on the pbm web site and i hear great things about the whole company, they seem like they would go low enough, got good array of spring combonations and they get pretty stiff i believe, im leaning towards them because it says online that they have camber plates on the front and rear, and none of the others seem to offer thatDriftBoy07 wrote:lol
PBM or Stance. Im debating between the 2 myself, I may be getting a deal on the Stance GR+ so Ill probably end up with those coils.
haha your serious? i was always under the impression that it lowered the car cause it put more presure on the spring and then adding more when putting it on the ground will lower it morenismotuner1 wrote:i vote keep the tein. i have the super drifts and there great!! are u sure ur adjusting them right? if u are adding spring pre load u are going to raise ur ride height! dont they have seperate height and preload adjustments???? the superdirfts do. I thought all teins did except for the cheap superstreet dampers.
Correct.But pre load allows more threads when they're none left.sr20power wrote:From my understanding when you pre-load the spring you do NOT change the height of the car. You are only adjusting the load on the springs.
yeah well i was just doing what i heard workedILoveMyRHS13 wrote:Preload also makes the car ride like s***.
well i know that most coilovers come linear, but now i am confusedpandapants wrote:Most coilovers have linear springs.So it would take the same amount of pressure to compress the spring.Pe-loaded or not. Pre-loading just complicates other things like corner weight, valvingand the obvious, bottoming out.
i am pretty low right now, and i know their is a point in which being to low is less advantagous such as bottomin out and dd problems and what notsr20power wrote:OP..kind of confused on what you are trying to do here? I have Tein HE's dropped as far as they go. You will NOT get better performance with the car being soo slow. And you want to go lower?
Unless the is a big difference between S13 and S14, I'm confused.
But good luck with w/e yo do...
yeah they are just about the best out there, im probably going to sell mine and get theseFidel_Cashflo wrote:My PBM coils come today! My buddy got his last week and they are just about the nicest coils I can think of for $1000... I would buy em if they were $2000, theyre really nice coils. Im soon to be making an order for the steering angle kit, rucas, and tension rods...
