i am begining to think that they are bent because both are maxed out, and one side has 2.0 degrees and the other 2.5 degrees of negative camber
i needed more camber due to clearance in the front but i pulled my front fenders and now it isnt a problem, i would just like to eventually replace them and roll them and not have to pull them and run a little more negative camber but maybe not
and the he's are no where near butting up to the chasis at the strut tower
there is alot more room for it to be able to go but it cant because of the design of the plates
and i get what your saying about the LCA and positive camber...im gonna have to work out all these problems, still waiting on the federal return before buying the PBM or the DMAX so i still got time to think about everything
pandapants wrote:Here's where you run into problems.I have PSM coils.As low as they go.Camber plates maxed.Stock s13 LCA.And have about -2.5 degrees of camber.
Problem 1.It doesn't matter how long the slots are on the camber plates.You're going to be limited to camber b/c of the tiny hole provided on the chassis.You know, on top of the strut tower.
Problem 2.You'll naturally gain negative camber when you lower the car.But, once the LCA becomes less horizontal and more verticalYou'll start to gain positive camberTotally negating the negative camber you get from lowering the car. Essentially, the lower you go, the more positive camber.
DMAX on the other hand,Has slotted bottom Brackets for a little more negative camber at the wheel. PSM does not have this feature.
If you really want gobbs of negative camber,you're going to have to get s14 LCAor Adjustable onesand/or modify the top of the strut towers to enable more negative camber.
