J.P. Pascale wrote:ok i started taking the electricle tape off and noticed that the black and red wire is spliced with a blue and red wire i tested the blue and red wire fron the ignition switch and now i had 28 ohms after the ignition switch now im not sure where to look lol i guess i should just trace both of those till i find something grounding let me kow what you think
I dont know what you mean by splice. You mean someone connectedthe wires after the car was manufactured? If the blue wire is the accessorywire from ignition switch it should not be connected to black-red wire.
I dont have any experience tracing shorts and I have not seen anypractical detailed instructions on how to do it. I would try to isolatewhere the resistance is coming from, testing the wires for continuity at various spots with battery disconnected. Or, test for voltage drop while thewire is hot.
