hate to be a d!ck killjoy, but you noticed all those improvements in drivability because you had a failed coilpack on there before. you are comparing a broken part to a working one.HxC_Nismo wrote:i just upgraded to the splitfire coil packs (cause i kept on frying igniters cause of a stock coil back feeding to the igniter and frying it so i just said **** it and bought a set of brand new splitfire coils, since i plan on building my rb26 for 700rwhp when the money comes in) and ive noticed alot smoother acceleration and it stabilized my a/f at full boost, and ive also noticed it starts alot easier at lower battery voltage. cause since my car is a weekend warrior the battery slowly drains and when i had the factory coils i had to jump start the car cause the factory coils needed 12v to operate and the splitfires only need 11v or so to operate properly. and i just tuned my car on a dyno dynamics(heartbreaker dyno) and put down 340rwhp wich if it was on a dynojet i would of put down 370-390rwhp.(dyno dynamics and mustang dynameteter both read lower than what a dynojet reads.
IMO your just rearranging deck chairs on the Titanic if you keep the stock coils. They are expensive, and not all that easy to run out and get. If I ever have to do ignition work again I will either do a wasted spark setup or a set of 6 LSx coils.WhatsADSM wrote:
Otherwise if I can't get it worked out then I'll look into an ignition upgrade, and will likely start with some form of a CDI (maybe AEM twin fire) on the stock coils. And if need be I'll go with a CDI with new COP coils (like AEM pencil coils or CBR coils)
I totally agree with what your saying with the grass being greener. My reasoning was the desire to run a coil that is common enough for me to grab from an auto parts store in the future if it takes a dump. I honestly thought the splitfires cost more then 450 for the set. If thats the case, its almost worth going that route and keeping a couple of spare stock coils for backup. I don't like extra clutter from plug wires etc..gawdzilla wrote:thanks for the replies. i have run 19 psi before with no breakup. after doing multiple runs back to back which i will be doing at the track(and also being warmer ambient temps now), the ignition system hates it. i think getting a fresher set of coils would be beneficial, hence the splitfires ($450). not really seeing them as an upgrade, but more of replacing worn out stuff. oem new is 100+ each, and knockoff new is $50 each....
i really want to stick with oem style though. supra coils, ls1 coils, wasted spark gn, everyone has the grass is greener syndrome. supra guys run RB coils, ls1 guys run supra coils, GN guys switch to ls1, etc. etc. so I don't think any of those are really PROVEN either, other than like i said, replacing worn out crap with new stuff.
and yes, the issue seems to be over the 400 whp area. broke up a bit at 15 psi, 410 whp. broke up a LOT at 18 psi and pooped out a 445 whp.
A CDI system is VASTLY different from an inductive ignition. The charge build up on the primary is very high, and hence the spark build up will be MUCH greater on the secondary and through the spark plug with a CDI system. This is exactly why people earlier posted that the HKS DLI (CDI), or plasma booster (ignition amplifier so presumably CDI) has supported 1000whp on stock coils.240z4u wrote:
Evan
Couldn't agree more. I get a kick out of DSM guys moving from their waste spark to 300M/LS1/etc. COP systems STILL RUNNING WASTESPARK. Then you have supra guys switching to LS1, RX7, etc.... The grass is always greener.gawdzilla wrote:thanks for the replies. i have run 19 psi before with no breakup. after doing multiple runs back to back which i will be doing at the track(and also being warmer ambient temps now), the ignition system hates it. i think getting a fresher set of coils would be beneficial, hence the splitfires ($450). not really seeing them as an upgrade, but more of replacing worn out stuff. oem new is 100+ each, and knockoff new is $50 each....
Yea I didn't realize they were 450 either. Checked on ebay and low and behold yea they are about 450. Its pricey but not horrible.... Thats about the same price maybe even a little cheaper then the AEM twinfire.240z4u wrote:
I just hear so many bad things about having the coils in such a hot location, but realistically in any 240 its hot underhood.... its the nature of the beast.
Evan
if you dress it up in a loom and not having wires flying everywhere, it *does* look subtleDriftX wrote:z32 ignitor swap for the cost and abundancy..GM coil retrofit for cost and practicality.. just remember your going to have a huge black box in your engine bay.. but it has worked flawless on mine.
yep, seems to be hit or miss with the ignition. consider yourself luckyautocrossing wrote:I'm running 100% stock ignition with NGK Iridium 7's gapped at .028, last dyno was 622whp @ 1.5bar. I drive the car just about every day at ~550whp. I haven't had the first hiccup.
Thats reassuring, in that the splitfires may be more than enough to support my lowly high 400hp goals. .autocrossing wrote:I'm running 100% stock ignition with NGK Iridium 7's gapped at .028, last dyno was 622whp @ 1.5bar. I drive the car just about every day at ~550whp. I haven't had the first hiccup.
no, lots of work done to the head, 1.5 bar really doesn't do it justice but I'm in the process of re-doing my fuel system so I can crank it up.I have found that the coils like to be uncovered to stay cooler, I haven't had to resort to that on mine yet, but it's worth a shot if you're having problems with yours.gawdzilla wrote:yep, seems to be hit or miss with the ignition. consider yourself lucky
your coils must've had an easy life and are in great shape. i'm running iri 7s right now and they choke out up top whenever they feel like it. 622 @ 1.5 is a pretty good number. stock head?
Seen higher numbers than that on a stock head.gawdzilla wrote:your coils must've had an easy life and are in great shape. i'm running iri 7s right now and they choke out up top whenever they feel like it. 622 @ 1.5 is a pretty good number. stock head?
I can't wait to hear how this works out. That was my plan too.WhatsADSM wrote:Yea I would say you are a lucky one. and your coils are in great shape.
Anything over 17psi and mine will break up. I would venture a guess and say I am just under 500whp when mine start to break up at ~18psi.
BTW, I haven't updated yet because I haven't had a chance to work on the car. Hopefully I will get a chance to rerun the power and grounds, but the better news is that I purchased a brand new set of LS2 coils from an 08 vett for a good deal. So I will be making up a custom coil per plug setup (NON wastespark) with them, as they have better spark energy and built in ignitors. Dwell is a non-issue since I can adjust it with the EMS.
Evan
