Here's the deal. I've gotten in touch with James from WasabiGarage.com, and he said that he HAD a KA24DE intake manifold in the works, but it was discontinued temporarily due to lack of demand, so I asked him if I managed to stir up enough demand if he would resume production on the manifold. The short answer is Yes, he will, and I need at least 15 buyers for him to do it. His message follows:
[quote=""James""]the only way for it to be somewhat affordable(rangeof $300-400ish) is not to have the coolant tracksgoing into the manifold. this would affect the idleat cold starts. For those that know how it is withoutthat it would be fine. But those that are expecting a$2000 intake manifold for a $300 price range is what idon't want. Because this brings my company name downwhen they put up a review expecting $2000 quality. Mysr20det intake plenum is bigger on the inside to holdmore air. If anyone is local they can check out theitem. this will basiclly be the same. and it is aquality piece.[/quote]Basically, it will be fairly inexpensive, but it will cause a bad idle when the car is cold, due to it being expensive to add the cooland tracts into the manifold. I don't really see this as much of an issue, seeing as how at least my 240 heats up quickly. He also said if people were opposed to this idea, he could probably make one with the coolant tracts, but it would definitely be more expensive.
Now, either post here, send me a PM or send me an email if you are interested in this. If you do not believe me when I say that a significant problem with the power production of the KA is the intake manifold, then read on for a thorough explanation of why it is, for either NA OR Turbo applications.
B18B stock Dyno:
Duration: 220/222 (advertised) 185/
[email protected]: .395/.380
KA24DE stock Dyno:
Duration 240/248 (advertised) 210/
[email protected]: .367
As you can see, the cam profile of the B18B is much more mellow than the cam profile of the KA24DE. however, the B18B makes peak torque at a higher RPM, and the torque drops off slowly. In the KA, the peak torque (maximum cylinder fill) is at 4000, and the torque drops off VERY sharply very soon after it peaks. This is also evidenced by cam changes having very, very little effect on the KA24DE. Theoretically, the KA24DE should have a higher top end due to the more radical cams, but why doesn't it?
The intake manifold.
As in the pictures, you can see that the B18B has much shorter runners than the KA24DE, probably by close to 8 inches or more. When you're talking about trying to achieve a maximum cylinder fill at 7000 RPM's, 8 inches DOES matter. Also, the stock intake manifold contains secondary butterfly valves which further restrict airflow. I have also included a mock-up graph of how a dyno for a stock 240sx with a different manifold would probably look. Note that this graph is only an estimation, and any attempt to hold James or myself to these exact numbers will cause me to find out where you live, hunt you down and shoot you for being a flaming idiot.
You can email me at:
[email protected]
List of Interested People:
240SXforums.com:
SSDwellah(?)ch1873857wish ihada240slow4drUnoeganH.D.HUMPERDINK
NICO forums:
demcjklattr1Checkered-Member(?)BomexS13corn322(?)jmauld
and of course, me.
