Idle Surging Problem..Any thoughts...PLEASE
nismodave
Well I tightened up my WG actuator and it seemed to solve my low boost problem so far.
I went to the track and ran it down the 1/4 mile. when I hit 4th the car fell flat on its face.
When I came down the road the car had a surging idle. I checked the Vac lines and Intercooler pipes. I also tried another Z32 maf that I have, no help.
I guessing the Idler Air Controll Valve or the Throttle position Sensor has gone bad.
But I wonder how either of those could cause the car to fall flat.
Any opinions from you guys would help . Thanks In Advance!!!
Sr20 det blacktop from 180sx Z32 maf Blitz intercooler Blitz Blow off valve Greddy intake Blitz LM air filter Garrett GT25/40 .86 ar turbo 740cc Injectors HKS Step 2 cams Tubular manifold 3'' Blitz Stainless steel downpipe 5zigen cat-back exhaust Greddy O2 housing Greddy head gasket ARP head studs Tomei rocker arm stoppers Nismo Fuel pressure regulator Enthalpy custom ecu Blitz dual sbc-r boost control Blitz Turbo timer Apexi super afc
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
spark plugs, you may have fried an elctrode, check em
Grambos13
did you ever figure out what this was? please let me know I have a smilar problem
Grambos13
not positive but I think I found my problem. I went through my wiring harness the other day and found up by the battery try that my iacv wire was not even connected. I'll let you guys know after I get my harness back in.
afmafia
its doesnt metter if thats plugged in my is shot so i unplugged it it still runs fine
Grambos13
thanks good to know
