UltraYellow35th »
https://forums.nicoclub.com/ultrayellow35th-u50617.html
Mon Nov 13, 2006 10:27 pm
I had the same problem on my 1991. The problem with mine was that one of the injector seals was leaking. It is very cheap to replace your injector seals. I would recommend getting them from a dealership.... but a word of caution.... I had to do it 3 times before I was able to avoid damaging the seals on the injectors when I put them in. In the end, I replaced all the injectors too.... which is expensive.... but I kept having the same problems with the new injectors because I was damaging the seals.... and I was really trying to be careful!
My advice for when you pull your injectors out of your fuel rail:
1.) Lube the seals before you try to put them back in.2.) Be very careful putting the seals onto the injectors so as not to damage them.3.) I wish I would have "cleaned up" the area on the fuel rail where the small seal comes into contact with it... by that I mean polish it up, or make certain the surface is very smooth and without any kind of corrosion.4.) Test your fuel rail for leaks before you put it back onto the intake manifold. I did this the dangerous method: by leaving it connected to the fuel lines and wrapping a big trash bag around the fuel rail to catch the fuel if it started leaking, then turning the key to the on position to allow the fuel pump to pressurize the system.5.) In case you don't know how to de-pressurize your fuel system: Pull the fuel pump fuse out of the fuse box..... start your car and run it out of gas. Obviously you would want to do this before you start pulling injectors.... and it only works when your car runs.
That's about all I have. Good luck to you.... It was the most troublesome repair I've ever had to do.
Josh
