QFTsrpowered240sx wrote:word, dont sweat the motor, or "oomph" as you so eloquently put. get the suspension dialed first. swaybars, coilovers, bushings to replace old worn stuff, adjustable toe control/ruca/extended tie rod ends, brakes, tires. then take it to the track and beat the hell out of it learning how to slide. its easier to learn with less power, then increase the power as your skills improve. GO TO THE TRACK!! just because youre building a "street car" doesnt mean you should be street drifting.
ive seen this on a few occasions..sad sad sight.morbid wrote:First get a stock car and try drifting. You might end up hating it and buying all the drift-oriented parts for no reason.
Its one of the best platforms for drifting because you can buy one dirt cheap. Not because it's some magical uber-slider... Rx7's, Miata's and a host of others perform just as well when properly prepped.driftfan_hemi wrote:So a stock 240?
I love drifting. love everything about it. And from what i hear the 240 is one of the best platforms you can get for it.
i stand behind this post.jjdarkstuff wrote:No cage until you're good enough for tandum.....that should be a while really. Cage makes the car A LOT more dangerous just street dirving though without a helmet, so consider that.
Oh yeah, need a SA2005 helmet
Soem people like a welded - friend of mine got his professional liscence with a welded. Most people like clutch type 2 ways, makes the transition easier, less snappy..
coilovers (I reccomend Stance ) $800-1200clutch (exedy stage 3 is WICKED) and maybe flywheel $300-600rear arms for camber adjustment (coilovers should have pillowball for frt adj) $150-300
As you get more into it, get a 4 point harness, seat, more suspension, etc etc. Stating off with a stock KA isn't too bad, but in all honestly it's a bit too slow on the street for me ya know?
f you look for a bit, you can really find a decent sr swapped car with coils / some suspension for 4-6g's. Not really too bad.
Do you have a shell to start with already? What all do you currently have?
in my track car i have (as far as drivetrain and such)stock KAtein basic dampners tein camber platestein tie rods, inner and outertein strut barsexedy stage 2 clutchfidanza flywheelinjen intakeapexi n1 dual exhaustwelded difforigin labs body kitand alot of little mods that saved weight, stiffined chasis, made the car more powerful, and got rid of stuff i didn't need. pretty much gutted and then some.
the car comes out awesome, even on the street. just got caught to night, but no trouble. the popo like me cause i work on their cars. muhahahaha.
the only reason why i would need more power is to smoke the tires on the straights of the track.
turbo on this car is comming in the winter, because i learned how to drive the right way.
and even now sometimes i can overpower and spinout.. werd
Yes, 240's are wonderful platforms for drifting.driftfan_hemi wrote:So a stock 240?
Well I look forward to this! I can already tell Im gonna spend wayyy too much time on here but it will pay off in the end.Chukidori wrote:
S13's in particular because they handle horribly in stock form. More specificaly, they are ridiculously understeer biased IE the car tends to push the front wheels more, and the *** end doesnt readily swing round which is safer.
When drifting, after you have FORCED the *** end out..Its very "stable" and you can safely dog the piss out of it sideways without worrying about spinning out so much..
Ahh ha. I guess that's where this guy got it from ....zerothread/358617moulton712 wrote:on big thing though is i'm contemplating on taking out my fidanza flywheel. then re-surfacing and taking some material out of my stock flywheel.my biggest thing at the track is when i go to clutch kick you need a little weight on the fly wheel to get a good kick in. but for p-lot events and other places where i'm allowed to go, the light flywheel is fine.
